I don’t want to burst your bubble but tooth picks are not the same as peg wood.
Birch wood is used for tooth picks, dogwood is used for peg wood. Birch is harder.
No bubble.
If I run into a problem, I’ll update here. But hardness is similar, actually a bit softer, for “birch” which has several varieties. (I picked the high and low hardness variety, since you wouldn’t know what species you’d get)
Flowering Dogwood Janka Hardness: 2,150 lbf(9,560 N)
Gray Birch Janka Hardness: 760 lbf (3,380 N)
Sweet Birch Janka Hardness: 1470 lbf (6,540 N)
Soaking in Ronsinol softens the wood further. Primary use is cleaning jewels for me.
No one need do what I do. Just sharing.
I have seen “Beech” listed as the wood species of peg wood.
Im going to presume European Beech, since that’s where the use originated in watch repair.
Janka Hardness: 1,450 lbf(6,460 N)
that seems to be more in line with Birch as well. In these small sizes, it is hard to differentiate the hardness. In a 4/4 broad, it’s much easier.
Hornbeam is another name for Dogwood, although there are variations within the type, where one might be called one and not the other.
Like Birch, I suspect there are several species within the family, with varying hardnesses.
I would say, if you can put a fine enough point on boxwood/Hornbeam, you should be able to do it with Birch as well. 600 grit paper should do it.
Something like Swamp Ash, with it's very open grain, I could see it not being possible to sharpen to a fine point.
I'll let you all know how I do with my toothpicks, if there are any breakage issues etc.
Anybody try using the bamboo skewers?  I can get a nice point on them, and I've used them for modeling tasks, but not on watches yet.  Thought about trying.  You can get loads of them cheap.  And they are more inclined to bend before they'd go so far as to splinter.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
