maker identification
Lovejoy
hallo all , I'm hoping somebody may be able to identify the maker of a french clock for me ... the stamp is in the form of a 6 pointed star with the letters GC in top half with a religous cross shape in the lower half ... and  on the back plate is stamped   1 million   any help out there please . thanks
5 hours ago, Tudor said:
I'm guessing that cross (on the bottom) is a Swiss cross, and not a religious one.
Otherwise, I'm useless here...
Sorry it was a tad misleading for me to describe it as a religious cross , I meant the shape of it as against a cross indicated by the letter X . cheers
My thoughts are this is German the 1.Million is a trademark associated with a German company called Lenzkirch who where certainly producing clocks in a French style and also supplying other manufactures with movements in other European country's, it certainly has a more Germanic look to the construction the G.C trademark could be a retailer or importers mark.
1 hour ago, oldhippy said:
That is German. As wis1971 has said the finish is not quite up to the french standard. It could also be  14 day duration, those springs are mighty strong. The case might give us more info by its style and how it is made.
I'm in the midst of restoring the case so will post pictures once it's done and re assembled , thank you everyone for your help ...
have finished the restoration ... the case is a fairly standard construction .. no fancy dovetail joints in this one , all butt jointed with nails inserted on a hit n miss basis  BUT it's held up well and required minimal attention ... further research seems to support Wls1971 that it is a German movement  1 million series 22 .. I believe ... I can't help feeling that the case is French made , it's right up their alley but I'm not sure and not bothered either .. have attached a couple of pictures including a side elevation showing the coffin like shape ... Thanks to everyone for their help and research , much appreciated ..
You are correct that case is French and a very nice dial the movement has. Quite a common type of French wall clock.
Here is one I found with just a normal dial.
https://www.bolk-antiques.nl/inventory/clocks/a-very-nice-19th-century-antique-french-wall-clock-signed-friry-laurent-a-bar-le-duc-height-51-cm-price-875-euro-1211593
That's nice too ... I love that shape ... cheers for that
9 hours ago, oldhippy said:
thank you for that .... had a look, nice clock ... if only not so far away ... there was another one listed in Holland that's similar and their translation of oeil de boeuf was " small round window " which makes less sense to me than "antique bull's eye " .... I'd better get the French dictionary out and see ... oh well , never a dull moment where research is concerned . Cheers
A thought just occured .... I have another oeil de boeuf clock that is round so maybe both translations can be applied to this one ?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
