how to remove scratches from watch
By HectorLooi · Posted
I don't. I just spin off as much excess as possible. I have a strong suspicion that #111 and Rinse #3 contain a high percentage of kerosene. -
So, looking at my own module, I can see that there are actually oil sinks on the outside of the jewels. I am going to apply oil in the conventional manner and see how it goes. Actually, this is interesting. A third version of a service guide for this movement. I did learn that the 0.6mm 'gauge' for measuring the chrono second wheel depth is actually a screwdriver tip (this is sensible, the others just show this as a cylinder shape so I used a micro drill tip). It also provides minimum amplitude for the base movement in horizontal and vertical positions and vertical positions, after 24h with the chrono running.
By LittleWatchShop · Posted
How do you rinse so as not to contaminate 111? -
Thank you. I tried both push, lift and slide without success ... I will keep researching
