Hello!
I'm trying to find a lower Incabloc spring for an Omega 613 which broke (now that's a first) while trying to reassemble and JB lists these two. Does anyone know what is the difference between them? Google and the parts list were not helpful.
Any help would be much appreciated,
Rafael
I think you'll find the picture at the link below helpful and confusing. I wonder if they had a design change because if you look there both distinctly different. But knowing what you have and looking at the picture you can figure out which one you need. then of little importance is the Omega spring would be rose gold color these will be the standard gold color.
http://www.incabloc.ch/images/cat/tableau-synoptique.gif
Thanks John! Much appreciated. It's definitely the 175.03.
Edited by Rafael
Would this be correct for the 565 lower spring as well?
I have a bunch of 270.03s on the way but I may be able to add the 175.03 as well, if that's correct. I couldn't find the cross information!
I have a link for the Omega 565 parts below. which casually looks confusing until I look at up above it does appear to be identical at least the same section that's been snipped out up above versus the section down below. But it's also confusing because their listing several different springs and there's a reference to Kif.
basically the easiest way if you still have a spring left is to look at the link up above the image and see which spring corresponds the one you need. Fortunately when they using Incabloc parts other than a variation of rose gold plating versus the gold plating they do appear to all correspond to the same size or the sizes that specifically Incabloc made that are found in the table at the link above.
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=OME_565
It does appear that way, yes!
I have two messages in at Ofrei, where I placed an order earlier today. I hope they get it to add five of those springs to my order!!
