Hi,
Just bought this today and the watch is working correctly (time, date).  I can set the hour and date using the crown.
Issue is with the small flush button above the crown used for setting the seconds and minute.  The button seems to depress but nothing happens.
As i say the watch is actually working and the time is correct.  But having to remove the battery to set the seconds and minutes is not ideal.
thanks
 s-l1600bg.thumb.jpg.400c7f64b7890f11d9a67a316de17205.jpgs-l1600.thumb.jpg.d716de848fd495ac5db2e9502e17b86f.jpg
Try fast tapping it. If that advances the seconds hand a bit you know the switch is working but the circuitry that advances the minute hand is buggered.
Otherwise open the back and short circuit the switch with some tweezers for 4 seconds and then let go and press again.
If that fails then you need a circuit board (9600-1337) omega part number.
They are rare as hens teeth.
I bought the last lot on ebay.
OK if you short across these the second hand stops.  you can wait for the actual time to catch up and release.
So you can stop the seconds.   but afterwards the button still does not work.
Just a thought- is the button OK? It appears set deeply to me. I thought these were just below flush. Perhaps it is making contact all the time?
Im also guessing there is an oring in there. Was that replaced?
Maybe take the movement out of the case and see if it performs properly.
Ok.  The plot thickens....
Went to change the crystal out today and while doing so i decided to take a look at the push button and contacts.
It appears that the previous owner got a bit heavy handed with the button and has bent the lever behind that touches the contact.   attached photos.
So bypassed this and touched the contact directly.  No issues with the circuit board as all works as it should.
Question i have is regarding the push button.  as you can see from the pictures when i removed it from the case it was covered in a black sticky tar like substance.  not sure if this was the gasket that had just broken down or someone used some sort of glue.
What should be here, also once pressed what causes the button to come back out.  see no spring???
That WAS an o-ring and it may rely on the lever on the movement to push it back out.
The stuck o-ring probably caused the excess force used. The lever will have to be straightened or replaced as well.
See if you can find the tech sheet on the case by case reference number, which will have the exploded view of the case assembly. (Plus part numbers)
Hi, didnt require any parts.   The lever was not bent it had hopped over the front rim (a raised edge to keep it inside movement perimeter).  Once i removed it and reseated it was fine.  small tweek with pliers and all good.
Bought a full box of assorted o-rings a few days ago, so when they come in i will fit to pusher and replace.
the one job i started out doing (replacing glass) didn't happen as i ordered the wrong size.....
thanks for advice.
That's good news!
The o-ring, when soft, may provide the "spring" as well. Be sure to lube it lightly with Molykote 111.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
