Hello Experts.
I just bought an vintage lady Omega. The spec is listed below.
Unfortunately, it is missing stem and crown.
I am confused about with stem ref which will be the correct one to buy.
Please give me your advise. Thanks
OMEGA2849
OMEGA TWO HANDS LADIES MANUAL WINIDNG WATCH
Feature : Two Hands and Manual Winding
Dial Features : Original Dial
Dial Color : White
Markers : Golden Arrow Figures
Case Material : Top Roll Gold Case With Stainless Steel Back Cover
Condition : Used and Excellent as per its Age
Sign : Signed on the Dial, Crown, In Side Back Cover and Movement
Authentic : All Watches displayed are 100% Authentic and Original
Crown : Pull
Band Type : Leather
Hands : Golden Hands
Movement : Manual Winding
Gender : Ladies
Machine No. : 620
Back No. : 511.215
Serial No. : 24587443
Jewels : 17
Case Diameter Size : 1.9 cm
Side To Side Size : 2.1 (Including Crown)
Vintage Ladies Omega Movement 620
Here are the list of stem ref that I found they are listing on eBay:
Omega winding stem ref: 620-1106, 620-1149, 620-1159
Thanks again.
Hi Johnvsd,
I just had a look on cousinsuk. They have 2 stems for the 620.
620-1125 -> 25.80mm (extra long)
6220-1106 ->  12.20mm
These are both 1 piece stems
620-1159  is a 2 piece movement stem
620-1149 is the negative part of the 2 piece winding stem (the inner part)
So everything depends on the case design. If the movement comes out from the back you can use the 1 piece stem.
If the movement comes out from the front  and you can't 'unlock' the stem through the back, you need the 2 piece stem.
In your case, the 1 piece stem is the one you need. I guess the normal length should do, but it's best to measure this to be sure.
Edited by PeterGe
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
