I've started listing some of the items that I found from inside the watchmakers desk and bank of drawers.  I found that a lot of the NOS parts like balance staffs have some surface rust on them from sitting for so long.  This was even the case on some that had clearly never been opened. They were stored in the original little paper envelopes/tissue type paper vs sealed plastic.  Do you guys think these would actually be worth selling?  I'm still in the process of going through everything especially the tools since there are quite a few that I have no idea what they are.  I'll probably post some pictures of those at some point to get clarification.  I'm hoping to make enough money to help fund what I need for TimeZone Level 2 (course/materials).
Examples of the rusted parts below.
I'm no expert but, to me, the rusting looks a little too far gone for a delicate item like a balance staff to remain true - even after cleaning. Hopefully, someone will prove me wrong!
Agree with Will really not worth the chance of fitting as the poise will be almost certainly out. Might be good as a template if no balance and the balance is of a known caliber.
All of the parts are labeled so I at least know what movement they're for but seems like I might be tossing them  Pretty sad because I've almost filled a whole sandwich sized bag which are mostly staffs and stems.
It's a shame if the Hamilton balance staffs aren't usable - I don't know about their wrist watches but Hamilton pocket watch staffs are moderately fragile and can easily be broken if the watch is dropped. And they're not easy to resource, so - if you have them in good condition - they're worth  selling for a reasonable price.
I'll have to go through and inspect each one to see if there are any that are free of rust.
If you advertise them correctly and wit photos then the decision will be the buyers.
Re poise- any weight loss will be close to the axis = negligable impact.
If there is any rust on the pivots, this would be a good reason not to use.
I would say that the staff in the first picture, where there is a lot of rust on the pivot, is trash. The one in the second picture is OK..\
Anil
Finally got around to cleaning up most of the miscellaneous tools. What's worth keeping vs selling? I don't know what half this stuff is besides the screwdrivers that I'll sell since they're pretty small.
Man I wish this forum had drafts because I typed and labeled what 90% of it is, and then it disappeared when I linked an image.  :thumbsd:
Were you ever able to recover your post?
Yeah, I know some are clock tools, just don't know what they're called.  I actually have a whole bag of random clock parts, mostly random gears and large springs.  Not really sure what to do with it since nothing is labeled and most parts have surface rust.
I don't know, being a pack rat myself, but is it possible to "clean up" the parts and store them for a rainy day (well preserved)? In my very little experience, most of the time when a part or a tool is needed it is the one we got rid of...and usually very hard to find again!
Just a thought...and considering their precedence is from another watchmaker, I wonder if further down the road they could be useful.
Cheers,
Bob
Cheers,
Bob
I feel that way with some of the watch tools/parts if they'll be useful but I have no interest in clock repair.
  1. Looks like a gem setting claw tool
  2. Sleeve Wrench?
  3. Ring cutter (Broken)
  4. not sure
  5. Graver
  6. not sure
  7. sleeve wrench
  8. counter sinkers
  9. not sure
  10. custom pliers
  11. Wheel truing tool
  12. same
  13. Diamond gauge possibly
  14. Pin vice
  15. sleeve wrench
  16. screw drivers missing the blades
  17. roller removers
  18. mainspring winders
  19. pin vice
  20. broaches
  21. not sure
  22. not sure
  23. hammer head
I think 9 is a cam lock hand vice, 4 is a pallet stone warmer for setting pallet stones in hot shellac. 21 might be a tool for soldering on dial feet.
Just my thoughts.
Thanks everyone for the responses. I'm going to determine what I want to keep then I'll start listing the rest on eBay.
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
