Hi to all members
I was browsing online for technical manual for rolex 1570 movement and I came across this ' page ' which seems to be from a book
Does anyone of you recognise it?
Seems like a really informative book
I'll attach an image of the page
Thank you
Its free to sign up. I suggest you sign up and ask the person who put up that photo. Knowing Rolex it might be info only to service agents. Years ago back in the late 70's Rolex were one of the first to stop supply parts to suppliers of watch parts. You had to sell there watches in order to become an agent and then they still wanted you to send the watch back to them and charge the earth for a service.
Hi Oldhippy  that business model is still in practice today aka  SWATCH and others.  Its that modus operandi that is the decline of the independant watch repairer,  regarding the newer watches. The Older and Vintage watches are being repaired at cost by specialists  and Hobbyists, Which is a good thing as many a good watch would have been consigned to the bin.
Yes and thank goodness we have them. Due to poor health I had to pack it in around the late 80's. That's why I remember it well. Parts for watches were so easy to obtain in those days. I'm glad I switched to clocks back then.
Thank you for the information Hippy
Was just curious as the book seems to have good info
Will try and register and see what happens ?
Thanks to JOHNR725
He sent me a PDF copy
It's the Rolex TSI( technical service information)
So mystery solved
Thank you JohnR725
18 minutes ago, Ramone said:
Thanks to JOHNR725
So mystery solved
Thank you JohnR725
Excellent news well done JohnR725.
I think technically the answer above to the question is not correct. Then because it's mentioned I will attach the file that does have the above information but it is not where the picture above came from.
my being nitpicky is because notice the above images in color. Rolex is interesting for technical information. We have PDFs of parts lists you can go to cousins for those. there are a couple of older technical documentation's usually they can be traced back to AWCI in PDF format. Typically everything in PDF is older black and white and like the file attached not very good image quality.
Then there are the physical manuals that are printed on really nice paper in color with lots of technical detail that no one has ever scanned PDFs as far as I can tell. my guess is the image above came from one of these newer color printed manuals. If you're curious about what these look like go to eBay search for Rolex technical typically it's a seller in Italy. They definitely look very nice and unfortunately they're expensive. I'm guessing as long as you're selling the original physical documents you are not violating the copyright.
My understanding now is everything Rolex has is online supposedly cannot be copied and we will never see any of this because no one is going to risk the wrath of Rolex if they do anything not appropriate.
ROLEX TSI HSL EDITION 1424816874_ROLEX TSIHS LEDITION.pdf
ROLEX TSI HSL EDITION 1424816874_ROLEX TSIHS LEDITION.pdf 1.29 MB · 8 downloads
Thank you again JohnR725.
With swatch group restrictions on all parts and manuals,  they're getting harder and harder to find
Thanks again
That's a newer TSI. I got excited when I heard a PDF was available, but not of the new version... The newer one contains info on the ceramic bezel models, which are totally different from the older sapphire crystal models (i.e. 16610). I have some exlpoded views of the newer cases and other small snips of information but not the complete TSI.
If anyone ever comes across it, I am very interested in getting a copy!
5 hours ago, Tudor said:
TSI
what exactly is a TSI? then I'm assuming the letters actually represent words what would they be?
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
