Hi all, I have been using this Meyers movement holder no58 that I perchased here in Australia for a while now and I must say, they don't make things like they use to. It's easy to set up and it holds all movements regardless of sizes, shapes or form. I have a Seiko 6309 plate in there that I just jeweled the barrel arbor port in there and the other movement plate is an omega 485 ladies movement plate. It has 4 different clamps that slide in and a quick release button where my finger is. It does not rock or come loose. The movements have no sharp corners intruding into the plate because the clamps are rounded. I have about 10 different movement holders including bergeon and this beats all hands down. What do you think?
Edited by Graziano
I have grown to appreciate dedicated movement holders.
The ones I can’t buy, I just make.
But this design looks much better than the burgeon one I have (and no longer use). With four points of contact, it always seemed to be putting pressure where I didn’t want it, or blocking something.
Yes that's what I am talking about. As soon as you take the balance out especially ladies movements the corners of the bergeon slip into plate and it shifts around loosely. One other movement holder I use is the old marshal one with rounded plate clamps as in the photo below.
Just picked one of these up on eBay. Hope it is worth 75 bucks
Hi there Mr jdrichard it is a brilliant holder, let me know what you think when you try it out. Did you get the complete set of sides? There should be 4 pairs. Holds all size and shape movements. Yabbadabbadoooo!
I believe it is complete but have not yet received it. I also purchased the Marshall movement holder that is on this post as I am sick of the current crappy movement holders. Poor engineering. So BAM! I will now have the best:)
  • 7 months later...
Update. Picked you another Meyers #58. These are the very best for all watch work and especially for pocket watches. I now have two, yes 2, of these.  Bought this one on eBay and it was dirty as heck. Ultrasonic cleaning then my buffing machine then a lot of elbow grease and tada.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
