Hi,
I am working on Breitling with Dubois Depraz chronograph module. Is there any technical documentation in terms of lubrication and assembly?
I am looking at Mark's videos which are great but was wondering if there is something I could actually print out.
Thanks!
No there's isnt any, here some answers for this kind of question that pops up every once in a while:
DD does not publish any specification about their products.
DD does not sell spare parts to anyone.
DD does not service or repair their products with the possible exception of their OEM customers, under a secret business agreement.
[not technical rant starts]
DD does not advertise or otherwise make themselves visible, for the joy of their OEM customers.
Are you a watch manufacturer? Then the choice is your, design and manufacture your own cronograph movement at the cost of very many million francs, to be prices many thousands for a chance of be profitable,
Or, buy a ready module from DD, for a chance of selling the watch starting 1,000 CHF possibly.
I have one on my Tag Heuer 2000 Chronograph I'm going to tear into as soon as I get this cursed Omega 565 off my desk.
I'll just wing it I suppose, as I was planning on asking the same question.
The good news is that I have two complete movements; hopefully one makes it off the desk alive...
I think Christian at Watchguy did a tear down of one of these. May be worth checking his documents page.
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
