Hi all
I have a seiko dual analog and digital watch from the 80s that I love but I was wearing it one hot day and it stopped working I thought it might be moisture and if I heat it up with a hair dryer it does start working then stops again.
I have took the module out I dont know if someone out there can see anything that might be causing it not too work any help would be much appreciated.
many thanks
Hi. I see a couple areas of concern:
that dark green area at the top may be corroded enough to break the trace when the board expands.
And the connections at the bottom are also quite tarnished.
Then in the zoom of the image I see the entire center area has darker green traces, and I’m wondering if they are all corroded or if there is something over them intentionally?
But the first step is a careful and thorough cleaning!
Always start with the least aggressive (deionized water and a q-tip) and then proceed up the aggressive scale carefully. Perhaps a pink pencil eraser (not the gritty “ink eraser”) would help after the water.
But you need to get your nose in there with the loupe and really check for breaks.
And be careful! There boards were not intended to be repaired, and are very delicate.
Hi  other than what Tudor has advised  i.e.  cleaning the contact areas carefully  check  it out for dry joints  as the symptoms you describe are indicative of that or contact problems.
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
