Could someone advise me if this is broken? I can't see to get the wheel to fit (in the bottom jewel or in the bridge, my movement has a bridge purely for the escape wheel)  and when I do get some sort of fit, it's loose and never really bites the second wheel unless at an angle. When I was stripping the movement, I made a huge rookie mistake and the wheels feel out, so I didn't get a good look at how they were all connected (now I am in a world of pain lol).
If I have broken this wheel then it would explain a lot. ST36 movement.
Thanks guys
hopefully I will be able to contribute and not just ask question further down the line. ?
Edited by boss0boss
dupe picture
6 minutes ago, oldhippy said:
Sorry to say yes you have, both pivots are missing.
Thank you for confirming.
I am OK with this though becauseI have learnt some good things here! I identified that this could have been my issue (it was), need to work on being even more gentle and now I know what not to do (although I can't promise I won't do it again).
I guess seeing as this was my only movement, I need to get a new one? or are parts for these Chinese movements readily available?
If that fell out, and wasn't forced out, it seems the pivots were already broken before you disassembled it.
If you "ripped" the wheel from the stones, it is possible to break them. Check the stones to see if the remains of the pivots are still in there, and remove if they are. Unusual to see BOTH pivots broken off...
This is definitely broken on both ends due to me most probably being to heavy handed and not giving the respect need. Definitely can take a lot from what happened here, as I mentioned above.
I appreciate you all confirming tho.
ST96 are not chinese movements unless this is a copy? I have seen some ST96 where the finishing is very poor but they were still swiss.
Anilv
Anilv
Isn't ST96 made in India now?
OP's is ST36.  How does it compare to the Swiss made? haven't seen one upclose.
You sure have ?.
If that is any consolation so have the rest of us.?
What helps break more, is dried oil that tends to keep the pivot stay put, you then wrestle with and break it.
Perhaps a pre- wash of mainplate+ gears+gear bridge prior to disassembly helps  pivots get unstuck.
It looks to me like you need something truly affordable to practice the basic skills. I'd definitely recommend you pick up a lot of used Vostok calibre 2409 or calibre 2414 movements. These movements are likely some of the most affordable on the planet and will, in my opinion and experience, give you 80 % or more of what a Swiss movement will for a fraction of the cost, and you'll always have spare parts for next to nothing. Here is my service walk-through and ode to the Vostok 2409 calibre if you'd find this to be an option.
Ooops my bad.. read it as 96.
Anilv
Yes! Yes it is... ?
Thanks for the advice and link to your service walkthrough. Very useful indeed and now my afternoon is going to be looking into Vostok calibre's.
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
