Hello
I hope this is not to big an ask. Can someone please post a link(s) to an assortment of stems, crowns and crystals they bought and feel like the kits are a good addition to a parts inventory.
I've recently bought a watch that is missing the stem and crown. Instead of trying to figure out the correct size of each then ordering a single set, I thought it would make more sense to order an assortment and try and select the correct size from a variety of sizes.  For example, would an ETA stem assortment be a good place to start or does someone know of a generic size lit? The watch I'll be restoring is suppose to be a 1940's Bovet, however I haven't opened it yet and so don't know the caliber nor to much about the watch itself.
Thanks in advance for any help that can be provided.
Michael
My feeling is, there are just too many variations. Unless you are a professional, best to order specific to requirements. The stem you need will become clear when you identify the movement (help from members here, should you need it). For the crown, you need the exact model number or, failing that, old photos or just personal preference to choose the style. Then it needs to be a fit to the stem and tube, with the correct sealing.
The best advice I can give is always try first to get hold of the correct stem. That way you can be sure all fits well. In my days you could buy unfinished stems that means with a little modification you could machine one to fit. Build up stocks of stems and balance staffs as well as crystals in fact build up stocks of everything that you need to repair watches. I go onto ebay everyday and I find loads of old stock of watch materiel. If it was me starting out that is where I would start.
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
