Dear watchmakers
I just serviced a Landeron 47 which is in good condition over all. But I could not get a decent result on the time grapher (watch runs too fast, huge beat error). After digging deeper I found the following.
The regulator arm pin on the balance cock is too far away from the centre of the balance in relation to the hairspring pin fixed on the balance cock. This causes a lot of distortion of the hair spring when everything is assembled. I guess someone in the history of this movement upgraded the balance setup with an Incabloc and used a regulator arm that does not fit the dimensions of the hair spring (?).
Furthermore I noticed that the pin’s location on the hair spring is somewhat wrong. There is a long overhanging section of spring. The hair spring itself is fine.
What are your suggestions?
  • replace wrong hair spring (probably not)
  • manipulate the hair spring: shift the pin to reduce the overhang and to reach the regulator pin (not sure if I am capable to do this)
  • replace the regulator
  • downgrade the Incabloc to the original non-shock proof setup
  • Others?
Best wishes
Hi,
you can do as proposed by AshF, but a slight bend at the marked spot will center your hairspring:
It will move the collet at right angle to the line spot - hs center.
Why do you suppose  an original non-shock? How does the jewel in the plate look like?
Frank
Your third picture shows stud sitting at the begining of the TERMINAL CURVE( right after the bend), whereas it should be at the end, "end of hairspring"  Just like ashF shows.
Mount the stud in stud hole of the adjustment arm.
Unpin the hairspring.
Thread the hairspring through stud hole all the way to the end of hairspring.
Re-pin.
You have a good terminal curve already, minor manipulation like this is routine.
Thank you all for the tips.
I will try the method provided by Nucejoe.
@praezis I found lots of photos of Landeron 47s without incablocs and yes, the jewel in the main plate has an incabloc system as well.
Shock system, regulator arm and all other components are the right type. One you pin the stud at the end of hairspring, all will fall in right place.
The micropin( hairspring pin) doesn't look in best shape, replace or sharen its tip for reinsertion into stad.  Do you know how to sharpen a micropin?
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
