Opening clock mainspring barrel
HectorLooi
After careful consideration, I think solder would not work very well for this repair. The solder joints would be subjected to strain, which caused the barrel to crack in the first place and we know solder joints fail under strain.
I'm thinking of banding the barrel with a steel strap which is placed with some tension. I'm thinking of using a steel zip tie, if there is sufficient space between the barrel and the 2nd wheel.
On 11/25/2020 at 3:16 PM, oldhippy said:
Did the cracks start to open when you installed the spring? if not then it should be OK.
I installed the spring back inside the barrel yesterday and checked it this morning. The copper wire band is still holding.
But now I have a new problem with this clock. The strike mainspring is going to break at the eye. Is it possible to cut off the end and cut a new eye or should the spring be replaced?
Apart from that end if the spring is in good condition you can as you put it cut a new eye.
There is a tool you can buy that will punch a hole in clock mainsprings. I preferred to do it the way my master used to do it. Cut the damaged part off and file it flat and filing rounded corners on the end.   You will need to heat around where the new hole is going to be until it is bright red then quench it in old oil or water. You then punch a few holes in it close together and then with needle files file it out into a shape like a pear so the narrow part fits onto the eye in the barrel. Make sure you file the entire burr away you do not want rough edges rubbing together as this will cause wear.
Thanks OH.
I cut off the end and rounded off the sharp corners, then annealed about an inch of the spring. Then I traced the outline of the hole and used a high speed dental carbide bit to cut out the hole.
This clock seems to have all sorts of hidden faults. I wonder what's next.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
