12 minutes ago, watchweasol said:
Yes  Thats what I was thinking, that wat the free fexible end works on the detent. The other way round puts too much pressure on the formed end.
I think you're right, will be trying this shortly.
Looks like you were right and it in fact goes in with the open end facing up! (Pic attached)
Now the next issue is that the minute bridge isn't applying enough pressure to the date setting wheel or date corrector. If I press down on the bridge everything works as it should but if I try to operate it on it's own, the date corrector moves out of position and doesn't engage.
Is the cover plate absolutely flat? It may require some "tweaking" to remain flat once the screws are in.
Always start all the plate screws, and tighten them evenly- criss-cross pattern (when there are more than two) to set the plate evenly. Tightening one screw at a time, can twist the plate, and can also make getting the other screws in more difficult.
You probably want a tiny bit of D5 (or similar) on that post before setting the arm and spring, if you didn't do that already.
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
