Hey guys, so I’m having a problem with potentially the balance and or escape wheel. Did a complete coa on this movement. Also replaced the upper escape wheel jewel/spring/setting. Now the watch runs but, on the vibrograph shows a lot of time loss. When I press down lightly on the balance bridge a bit it stops, and have to turn it to get it going again. Been stressing me out. Checked all the pivots and jewels and everything seems fine. Any and all info would be very much appreciated!
Edited by Yallabye
Since you replaced that upper (in the plate?) shock setting you probably pressed it too far and now you have no end shake at all. You need a tiny bit of shake there. Less than the train, but more than zero.
Was it a Rolex part, or generic?
There is a bit of endshake. Is it supposed to be flush on the underside or have a very tiny bit of lippage? It is all genuine.
So you got some or little endshake,  just as a test: loosen cock screw 1.5 turn see if oscil speeds up.
 Do you see any shelac keepin pallets put?
You beat me to it, while I was compsing. fast typer.
Sorry can you please explain what the cock screw is and “shelac keepin pallets”
Cock screw is the one that holds the cock down on mainplate, in cases you suspect end stones might be pushing on pivot end( no or very little end shake) you can releive such possible pressure on end stones by loosening the said screw, if the are no end stones, the jewel itself can be pushing on shoulder seat of the pivot.
Shelac is the stuff that acts like glue but wont hurt the base metal over time, it is used on fork pallets jewels to keep them from moving in fork slot, nearly all petrolium base cleaning solutions dissolve shelac rendering pallet jewels loose to move in the fork slot, which ruins escapement at the pallets and can be a cause for a host of escapement disfunctions.
The amount of exposure doesn’t matter- the end shake does. Try Joe’s idea of loosening the cock screw and see if things improve. If so, you may need to press the setting out a hair.
Did you happen to do any hair spring work? At rest, is the roller in line with the pallet fork (straight line between balance pivot, fork and escape wheel)?
Ok so Adjusting the cock screw did help a lot but it is still about 1 minute 45secs losing still. I am going to press out the upper escape wheel setting and see if that makes it better, I’m hoping
out of curiosity why did you replace the entire setting?
normally the above answer would be fine except this is a Rolex watch. Rolex is obsessed with end shake so often times they will have procedures to make that adjustment easily especially on the balance bridge.  rather than explaining the procedure I'm attaching a section out of the manual. You'll notice there's a screw specific for adjusting the end shake. If somebody had zero idea what that screw was for an rotated it that would be the problem.
I replaced the entire setting partly because I was lazy of replacing just the spring itself because whoever worked on it before had broke half of the spring and left it like that so I decided it was easier just to replace the whole thing instead.
I adjust the regulating screw for the balance bridge, and also pushed the setting  in a bit more so the escape wheel has less endshake and seemed to make a huge difference. Within 10 secs.
Checking end shake on escape arbour will suffice. You would get zero end shake, if end stones are pushing on escape pivots.
Removal of end stones so to leave escape arbour unbound might create new problem, that is; you want escape wheel and fork pallet jewels level (both in same plane).
You have high percision gears in this piece, so power transfer through out the gear train should feel effortless.
 Thanks to john's post which shows the design provides an end shake adjustment screw.
Good luck.
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
