Hi guys,
I have this stainless steel bracelet that broke and I'm thinking about drilling the pin out but I'm afraid I don't know what would be best to do the job, having broken several bits in more forgiving metals before. Maybe the bits I use are not adequate? Normally, I use a dremel for all power work since I lack bench power tools, fixtures and even a regular bench!. Any advise will be greatly appreciated.
The broken pin is 0.54 mm approximately in diameter. Notice the link is "sealed" during manufacturing and there is no exposed hole to push the pin out on either end. Also, the hole at the other end of the link is plugged by the broken end of the pin ( broke flush to the hole) and the protruding end of the pin on the other side of the link can't be pulled with pliers as it is (on a preliminary trial). I haven't applied heat or any other treatment since I don't want to screw up the bracelet more that what it is now.
Thank you in advance for any help and/or thoughts conducive to solving this problem.
Cheers,
Bob
My first thought was to pull it out. However how does the new pin fit is a bigger problem. It might work as spring bar type pin.
Thanks CB, I tried to pull it out, it is not budging and the other side where should be a hole is plugged with the other end of the pin. Would you apply heat and then pull it? and what about the other end? the spring bar idea would work for me once the link is clear of the old pin.
It looks like it's riveted so the only way is to drill it out. I have a Proxen piller drill with a router table attached to get accurate drilling & getting the drill absolutely in the centre will be a problem without this or similar set up.I have had a look in my spares box & the nearest I have to it is an Omega strap. Looking under a loupe the pins that should be removed are screwed in then filed flat just wondering if the pins un-screws.
Edited by clockboy
How does fittings for the extra links with the hole near the clasp look ? Is it split pins ? You could use one of these as a guide when you drill out the broken pin . If you could make some kind of jig  You would need a long drill .
Edited by rogart63
This is a bracelet i have in a box . Looking a little like your bracelet . If you look at the first picture you can see it has a split pin . If i bend it open i can pull it over the pin post-644-0-26084100-1426510368_thumb.jpgpost-644-0-20973000-1426510696_thumb.jpg
Edited by rogart63
Thank you CB, I tried twisting it but to no avail. I will have to drill it. Any advise regarding what type of drill bit is necessary for this (rating, etc). I'm afraid the ones I have are not making a dent!...and I will have to make some sort of fixture for the dremel...it is hardly wobbly but it is at the tip just a tiny bit, is that normal? Would it be a problem either with the band or the bit at this scale? (0.54 mm or slightly less for a bit diameter)
Thank you Rogart, the expansion side uses split pins but this is the part that can't be resized. It is actually close to the watch lugs, just the previous one to the one which attaches to this particular case. I wonder if they solder/weld them to the link.
Thank you CB, I'll get both and report back after a trial run on this bracelet! I knew my drill bits were kind of wimpy since they broke so easily! I'm also checking on a fixture for the dremel. Nothing like the right tools for the job. :)
Cheers,
Bob
Thank you steve, I just ordered one from Amazon. The waiting starts! But they are quick so I'll be here in less than a week.
Cheers,
Bob
Thank you ligangyi, I'll try those too. Not very expensive so it is a good choice.
Cheers,
Bob
I use these myself occasionally. For your job spade or "D" drills would be a far safer bet. Carbide twist drill although excellent for cutting hard and special steels, they'll break with the slightest provocation. In your case you are not drilling solid steel, the slightest movement of the pin when drilling or if you are off slightly and it catches an edge between link and pin, will break the drill.
I concur.
And, what's worse, if the carbide drill breaks off leaving the end bit in the hole it's a devil of a job to remove it.
That's definitely the worst bit, and will probably turn your bracelet into a bin job! :(
I have used the Tungsten Carbide Drills for a while now being aware of the brittleness. The problem is the harder the drill metal although stronger they become more brittle. In my experience removing a rivet the hole to be drilled does not have to be the same width as the rivet a smaller hole seems to remove the pressure fit & they then just pull out. The spade drills work really well in a lathe with the piece to be drilled turning, such as a pivot etc etc.
The key to success for drilling is for the piece that is going to be drilled to be absolutely square & secure then plenty of lubrication  (spit,oil , etc.) and for the swarf to be cleared away as often as possible because this is what brakes the drills.
​For larger holes & to get absolutely in the correct spot first use a centering drill
Edited by clockboy
Guys that's excellent advise. Impossible to screw up now! I just need the right bits -- some are already ordered and some will follow! Thank you so very much, this makes my work so much easier and enjoyable. You guys are super!
Cheers,
Bob
Have you tried resting a soldering iron bit or fine burner on only the pin to heat it up to red, then douse it in WD40 then repeat the operation and leave it soaking for a while.  Might be worth a shot.  If nothing else, if it does not work and if you finish with the heat it may soften the pin a bit for drilling.
Cheers,
Vic
Good advise Vic, I ordered the bits so I'll do that while I wait for the package. Thank you for the advise!
Cheers,
Bob
Am I right in thinking that you will have to drill from the outside in as the U shape prevents a straight shot at it from the inside.  The accuracy will have to be spot on even with a drill stand.  I don't suppose you can get spare links from the Bay instead can you.  Is it a vintage bracelet or a particular brand of some sort, you never know one of us may have something lying around.
Cheers,
Vic
Yes Vic, you are correct, the shape prevents me to drill it from the inside. It is actually a Citizen so called "solid link" bracelet that is shaped for that specific model watch. I'm not even sure the back of the watch is the original one even though it is Citizen and fits perfectly. Therefore the number to identify the bracelet may be off. I will post a picture of the watch case later on.
Cheers,
Bob
It's often possible, believe it or not, to actually punch these out, if you have a strong enough steaking pin, or bracelet punch, or failing that, I have found tungsten-steel darts (that's right, the things you throw at a board) excellent for difficult bracelet work as they're practically indestructible. (obviously unscrew the part that holds the flight)
You'll need to get the bracelet secure, either have someone help you hold it against a vice or put it into a drill press vice, and hit it on the right point of the side of the link, once youve made a little dent, start hitting it very hard with sharp taps. It should eventually budge, with some (sometimes a lot) of cosmetic damage and usually a rather large hole is left, so have extra thick split pins or be ready to make a custom knurled steel pin.
Me and my boss have repaired a number of bracelets this way where they've come apart at the permanent, factory fit links.
A lot of you are probably now thinking "that surely can't work." It can, it's brutal, but it works. You often have to spend some time polishing and tidying it up, and selecting the right type of pin to properly secure it back together, but often there's no other option.
Edited by Ishima
Thank you Ishima, I will get the darts for sure! Looks like a sound idea to have some around too!
Cheers,
Bob
    • If the watch is new, just return it to the seller for a refund or replacement.
    • Keevo, Welcome to the group ! I'm thinking that you have some damage to the hour, and/ or minute wheel. Possibly just a bent, otherwise damaged, or missing tooth.   Your photo didn't post that I can see. I think you'll have to open it to start really finding the issue. Best, Randy
    • An industrial break cleaner , like Holts does a good job of rinsing off paraffin
    • In cap jewels on several watches I have serviced over the years. I've recently serviced a couple of Longines movements where the cap jewels were colourless. They are a real pain. Without colour they disappear when immersed in any liquid for cleaning 😲 Not necessarily. Cousins do a 10ml bottle for £26 which will last me for years. That's just half the price of a simple Bergeon silicone cushion, so not too expensive 🤣
    • I wanted to post an update as I have two movements running really well now, 230-250 amplitude , 0.5 and under beat error, and +/-8 seconds or so. I removed the hairspring assembly in order to start over and noticed that the terminal curve between the stud and regulator arm was distorted. The stud was lower than it should be. I massaged the curve to look pretty good and reinstalled it. I followed Alex's video advice, best I could with 10x magnification, and with the regulator arm set in the middle of the curve I adjusted the stud so the spring was centered. I then made sure I could move the regulator arm the entire terminal curve without upsetting the coils. I then put it back on the Timegrapher and began closing down the regulator pins until I saw a change in amplitude which means to me that the pins were now pinching the spring. I opened them slightly and it looks good except I have a 0 on dial down, +3 on dial up but -16 on crown down.  I'm a bit stuck on how to adjust out the positional error. I also noticed a drop in amplitude, 180-200 on crown down. In the other video link I posted at about minute 26 if I remember he adjusts out positional error by manipulating  the regulator pin gap. With crown down the hairspring falls away from the pin and the rate slows so he closes the pins a bit to keep them tighter in crown down position. That means the spring is tighter on dial up as well but then he moved the regulator arm to slow the movement.  There must be some Seiko experts here that have some methods for dialing out positional errors.
