On 11/27/2020 at 1:38 PM, jdrichard said:
"I always fear the balance cock falling off the movement on installation and the balance staying in the movement resulting in the hairspring getting really stretched. "
That is my nightmare, unfortunately I have witnessed it, not even once and I have not serviced many watches only a handful. ?
Just use your other hand as a guard while you are removing or installing the balance
I made some parts for this balance tool i Solidworks and 3D print out the parts in PLA                                             a very strong plastic, even case openersw  resist the forces, otherwise it is good to make different movements holders.
This tool was sold as "tool for filing balance screws".
Hence the "unknown" pin. Funny that the tool is still made with that pin without knowing its reason ?.
I had searched some time for # 30673 until I found mine.
I use it rarely but I am happy I have it when I need it.
Frank
Edited by praezis
I'm trying to figure out if I can make one with just hand tools i.e. hand held drill, files, etc.
I could use solder (and or pins) to fix the back plate,  solder the legs,  and buy a small brass hinge, again soldered on.
The holes for the pin which holds the balance cock don't need to be absolutely vertical.  I can tap them and use screws, but somehow have to turn the end of the screws down to fit the hole in the balance cock.
..... or I could buy a 3D printer ?
This is really nice!
Can 2-d drawings be made from the solidworks model? If so, I can quote having these made. I certainly want one, and the more we do, the less per they will be.
Aluminum will probably be the least expensive, but brass is what I would like to use. Perhaps chromium plating after polish for that over the top look (although we might want to lightly sand blast the top plate so it does not glare at us when working).
Anyone interested?
PS I think the pin sticking out is perhaps a guide for the file?
I think this is the new version, from our friends at Bergeon...
BERGEON JEWELRY/WATCH TOOL TO FILE AND DRILL THE BALANCES 6903 | eBay
That's awesome Frank, I've never seen one in a catalog. Since it was a standard student project I always thought they were simply never commercially sold. A Japanese friend here has the 30673 and really likes it, I'm surprised you don't use yours more.
Ennaj12, that looks great! I should point out that the semi-circle that presses on the balance rim is pivoted, so that it always presses evenly on both side. Not strictly necessary but a nice detail.
An old Witschi catalog from supposed early 50s. It has many funny timing machines from the era. Catched it years ago on the Chaux-de-Fonds museum fair.
Frank
16 hours ago, ennaj12 said:
Easy to get 2D drawings from model in Solidworks, it is in that program.
I can made them for you.
That would be great. Then I can refine them, with the details we know, and go out for quote. I'll get it quoted in Aluminum (6061) and brass. The big cost will be the labor, so I don't think it will be much different, but it's always nice to have options.
Thank you very much!
I can't today (parts to inspect) but I'll work up some refined drawings and go out for quote.
Out of curiosity, is anyone else interested in one of these? Making three will be expensive per piece, but price will drop with quantity.
Tolerance will be somewhat loose, so that helps control cost as well. Dies and movement holders have tighter tolerance, so higher cost despite their relative simplicity.
I would be interested:)
Ok guys!
Hopefully the bulk of the parts are out of the way now. I had to do like 40 blend repairs today... no power tools allowed. Swiss pattern files and cratex sticks.
I’ll keep you posted.
Ok, I spend some time today to make a brass balance tack for holding the balance without tension on the hairspring:
1) cut a tack on a lathe
2) tap it with 8-32
3) cut a sheet of brass square
4) tap the hole 8-32
5) cut 2 different sizes slots for the rolled table to fall through
6) screw in the Tack
7) buff etc
mistakes: tack at small angle, need to tap straighter, need small legs (4 blobs of Rodico being used.), lower the balance cock by tapering further down.
2) tap it with 8-32
7) buff etc
15 hours ago, Tudor said:
Looks good so far!
Tap the four corners 4-40 and put in four button head cap screws for feet.
Solved the leg issue. Former and glued on a piece of Leatherette that not only provides cushion for the lower pivot, but raises the balance so that legs are not required and there is less tension of the Hairspring:) Done!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
