Did a complete service on a vintage 1957 Rolex watch movement. After I ran the train following cleaning, all gears ran super smooth. Put the pallet fork back in and all good...nice snap. Then I removed the balance with hairspring and dipped it in lighter fluid to clean the roller jewel, table and mainly the hairspring. Agitated it with a air puff and finished all the work. When reinstalled, the amplitude was still poor. Had a closer look with stereo microscope and the was oil between the spring leaves. Removed the spring and cleaned it again in lighter fluid, but left it there do 1/2 hour. Did the reassembly and the watch ran with and amplitude of 200, Swing of 400 deg. Excellent! Then after 10 min, it jus stopped. Tested every thing then removed the balance and just put it back in and Bam! Worked again. Then I intentionally rocked it on my mat with small bumps and it stopped again. I then took a screwdriver and placed it under the hairspring and jogged it a bit. It again started. Then I noticed that the stud was not completely in place. Got the movement going again and slid the stud back into the slot and tightened the 2 plate retaining screws. Could this have been the problem? Watch currently running nicely. I am processing the video and will share it in an hour or so.
Center arbour spring shouldn't push on the said arbour's pivot,  a .01 mm tolorance is common.
How did you lube the interface between the pinion of center arbour and center jewel?
Hi JDR,
I’m not sure that your balance alone has freedom of movement. Can you install it with the movement wound-down and the pallets removed to check to oscillates freely? And presumably the end-shake and side-shake look reasonable?
A couple of other things, purely my opinion: with non-shockproof balances, I tend to be quite careful when screwing down the balance cock. If the balance isn’t visibly vibrating slightly then the pivot may not be seated in the jewel hole. So, if it’s static like in your video then I sometimes give it a nudge for confirmation. When nudging the balance wheel, I would use something light and flexible like an oiler, and not a screwdriver.
there must've been some reason why they invented this type of stud holder. If it was to torture the watchmaker that might have been the reason but there's probably some other reason we just don't know. Because the stud slides in and also likes to slide out when you're tightening the screws all sorts of undesirable things will occur. Then if the screws are loose then that definitely would be a problem also.
how is the watch currently running?
I keep fingers crossed.
In case the issue persists( keeps stopping)  I usually remove that center arbour=sweep arbour= seconds arbour, to eliminate this most common culprit with FHF70, its pivot sits on its retaining spring, that is metal on metal, on the other side of its pinion, your have pinion&(center jewel) interface which also requires special attension in oiling.
Easy to take out the sweep arbour, for start of elimination process.
In some versions a mini bridge was put on gears bridge, you would think that should have eliminated most relevent culprits, it actually didn't. Only FHF70 in which the minute wheel was incorporated inside ebauche solved the culprit , that version is truely a jewel, an excellent workhorse.
It seems to be running fine now but I will see if it wants to stop again in different positions. The way it would stop seemed to be dragging. I know the train is perfect as I ran the train a few times again. My thought was that the hairspring, that is now perfectly symmetrical, was rubbing in the balance arm, but I checked that with my microscope and it looks like it’s not touching. I also had a look at the roller table and jewel and they look fine as well. Will check and pray again this morning. Ran all night.
That is a great idea as the metal leaf spring pushed down on the center seconds pivot to keep it in place and I did not put any lubrication on this pivot.  Should I Lube this and with grease or oil?
Hi Jd, I once put the question to @nickelsilver the oil he recommended wasn't anything special, sorry I don't remember which oil he said nor the thread the discussion was in, more importantly is to oil the pinion-jewel interface as well and above all to remove/eliminate the center arbour just to check if an issue is there, in which case I am sure you are set to polish all interfaces on the center arbour.
Judging by your video that oscilator runs perfect.
Good luck.                    Regs
Good luck.                    Regs
It is running like a dream. Cased it this morning and polished the case at the request of the owner. She is blown away, and now wants to get insurance on it.  Here are my final pics. Will let it run overnight and then regulate it.
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
