Hi all,
I am dealing with quartz Seiko 7N42 movement which I want to replace, but can't find any stock with the suppliers. Would you know about any suitable replacements for this one?
The dimensions are:
Size Ø25.60mm (11½’” Ligne)
Height 2.90mm
Hour, Minute & Centre Seconds
Date @ 3h
Battery 371
Hands Min .65, Hr 1.10, Sec .2
Thanks,
However, if you can't wait then ordering Date @ 6 may be an option also, if you are capable of swapping the circuits, coils, stems, etc.
Movement, Seiko 7N42 Date @ 6h
The vx42 is a direct replacement, sold by Seiko for assembly into non Seiko watches ,as such it is marked differently. it is generally cheaper ,more readily available and the only time you would know the difference is when you remove the case back.
It doesn't look like a direct replacement, but close: Sec .18 Vs Sec .20
7N42   Ligne, 11 1/2.  Thickness 2.78.  Hands 65/110/20 Dial feet  1 x 7  cell 371.
VX43   Ligne 11 1/2     Thickness 2.92.  Hands 65/110/20 Dial feet  2 X 8.  cell 373.
So not directly compatible  so hang on in there for the correct movement. You would have issues with the dial feet and the height depending on the case depth.
VX42 was suggested, not VX43:
Height 2.62mm
Hour, Minute & Center Seconds
Date @ 3h
Battery 371
Hand Sizes: Min .65, Hr 1.10, Sec .18
1 hour ago, yankeedog said:
Please check my post  in watch of the day. Dated September  9.  I Put a vx43 in a 7n43 watch without  a problem.
I am glad it worked for you and I have no doubt that vx43 would work just fine in many case.
I simply noticed two differences: 2.92mm Vs 2.62mm Height, and Sec .18 Vs Sec .20 hand dia. I will take a look at your Sept 9 post. Cheers!
Thank you all for the discussion, I will try ordering the VX42 as the price is ok for giving it a go.
And yes the reason for this original question was the fact that the exact replacement is out of stock with not much visibility on the restock date.
Thanks.
Yes there may be differences in the height, the vx42 being a tad slimmer.It was my impression however that most, if not all recent Seiko Quartz movements had 1.10, .65 and .20 mm handsizes.
Some Seiko movements that I serviced were just under 2mm in height in very slim watch cases. Thus, I would not get any similar movements if they were even slightly thicker. Those movements did not have Sec Hand, just an Hour & Minute.  1.10mm & 0.65mm sounds about right, but I don't remember.
So, the VX42 did not work as the date ring of the 7N42 does not fit in there. I need to swap the disks due to a different colouring.
If you are not swapping the date disks, the movement swap would probably work.
So, I will be patiently waiting for Cousins to receive the movements...hopefully.
    • I’ve watched every video I can find on YouTube. Some of the info in contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
    • This eBay listing seems to verify that the watch disassembles as I suggested : here. The display caseback is held by the section that pushes out of the outermost rear bezel.  The movement seems to be a Ronda 1113. Best Regards, Mark
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
