IMG_20201128_165359.thumb.jpg.76c149c5ece5bddc632471959d6d24d2.jpgIMG_20201128_165346.thumb.jpg.9a6a78b5edb6d5a76586c060164af67a.jpgDear all
I wonder if you can help me identifying my 8 mm lathe. Headstock, bed and support are completely unbranded. The person I got it from says it's a Lorch. However I could not find any pictures of a Lorch without oilers like mine. The tailstocks of my 6 mm Lorch are compatible in that they have the exact same centre height. Could it be Wolf & Jahn ?  Have you ever seen a model like this?
I thank you very much for your help and remain with all the best from Hamburg
Alex
Alex
I think I have one of these??
To the best of my knowledge Boley & Leinen never made a Geneva pattern lathe, they always used either the WW pattern or a reduced form of that they called "Reform", which is what JD's appears to be.
Have a dig around Tony's site, probably has dozens of watch lathe makes listed with an immense amount of information on them.
http://www.lathes.co.uk
Thanks Nickelsilver. Tony has a 6mm Wolf Jahn which is apart from it's size identical to my model. I have now found reliably the following thread dimensions: Lorch 6,985 x 0,625 and Wolf Jahn 6,85 x 40G. I measured the thread of the chuck and it read 6,85 mm almost bang on. So it's a Wolf & Jahn. Compatible chucks with the same thread and pitch are Leinen (but not Boley & Leinen) and Bergeon.
Thanks and greetings from Hamburg, Alex
