I recently attempted to change a dial and hands on a watch I purchased with a selitta sw200 movement. I made a rookie mistake and pulled the crown out in the winding position. Of course this messed everything up and I had to research how to correct my mistake.
I've read several posts and watched videos on the keyless works and thought I would give it a shot. My first several attempts weren't successful and resulted in the same problem. I took a break and gave it one last shot as I thought I forgot to make sure the stop lever was resting in the groove of the sliding pinion. After getting it back together it now works except it won't wind, the crown turns with no resistance.  I don't know if I stripped some teeth accidentally when trying to repair it or if I neglected to do something during reassembly. It winds fine with the rotor, runs and sets the time and date correctly. I will have to take it apart sometime as when disassembling I saw the screw head for the setting lever spring was only half there. I am able to remove it and screw it back in but want to get another to replace it if I need to take it apart again.
Does anyone have any ideas as to what went wrong.
2 hours ago, canthus said:
Have you put the sliding pinion/clutch wheel in the correct way round.
That's what I'm wondering. I'll take apart again once I find a screw for the setting lever jumper.
I wonder if I somehow managed to put the clutch wheel in backwards. I'm prerry sure the sliding pinion is right because the time and date set fine. But the gear I can see through the back the gear that turns with the clutch wheel doesn't turn
Edited by Jimg1969
Screw For Setting Lever Spring ( 5445 ), ETA 2801.1 ETA280115445
What is your question then? Can't find that screw?
The screw that's current in there needs replaced and I don't want to risk breaking the other half of the screw head off.
Edited by Jimg1969
sliding pinion fails to return back and press on winding pinion.
I agree, you should replace the screw as the set spring is not firmly held down in place,  the U part of spring should sit flush level with and push the return bar back to engage it with winding pinion.
I can find someone selling the date jumper maintaining plate screw. That is the same one isn't it. I think the have different part numbers but are the same screw.
I am not sure if they are the same.
Can't imagine that this screw is 'special', I would measure thread dia and length of old screw, and looks like countersunk head, then try and source generic screw or stock screw.  Have you got a set of misc screws, you may find one among them.  Also check out the parts list as the screw may also be used elsewhere in the movement, to give more options. Probably also used in other Selitta movements, and even ETA.
I don't have and other screws here to compare. This is why I think they are the same
I think proper seating of countersink onto the sink makes it special. it can eventually let the set bridge loose and cause misfunction of set mech, troubbbble.
Why not get the exact correct screw?
Having trouble finding it. Either it's not enough for an order or it's not in stock or shipping from another country with a long wait.
I was under the impression they are the same though after reading, only the part number is different.
Appears to be the same part.
Sellita SW200-1 Part No. 5445, Screw
Our Price:  £0.50
SKU:  LWP.SW200-1.5445
https://www.leosics.co.uk/sellita-sw200-1-part-no-5445-screw.html
Our Price:  £0.50
Great thank you. I double checked the technical spec sheet and its listed there as the same screw. I'll check into the one you found for me as well. Thanks for your help. Hopefully I'll be able to get this working correctly again soon. 20201202_165523.thumb.jpg.8d4804d231fcd12c473128b4fb0fae84.jpg
Edited by Jimg1969
Glad to help. I myself was looking for a single screw 2709 for Omega. Nothing cheaper than $30USD plus another $20 in shipping cost... Not happy! ?
Ouch...
24 minutes ago, Jimg1969 said:
Ouch...
Here is the real OUCH: i ordered 2708, which seems to be an identical screw, but slightly longer. Not a problem, i thought. I would simply adjust the length. Paid about 8GBP plus shipping and.. still waiting ... 30 days later.. Probably should say Goodbye by now.
Yes, that's why international shipping bothers me at the moment. Still waiting on some watch bands I ordered 2 months ago.
Two month! I am not worried now at all :-). What bothers me that some parcels that i ordered later, already arrived. Perhaps that "lost" one was picked for inspection and will arrive with extra bill to pay TAX, fees, import tax, you name it. It was not just a screw - there were more parts in the same parcel.
Technically speaking a mistake but the biggest blame should be on the poor design by the manufacturer and the tens of others that copied it.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently! Another option:
