Timex Electronic from the junk pile
57 minutes ago, AndyHull said:
Bear in mind that the output would be 110 or 240 V AC, and might give you a bit of a whack if you are not careful.
No problem. I have experience working with 1000V vacuum tubes and 60kV transformers. Lost count of number of times I gotten shocks. ?
A typical electric clock consists of an asynchronous AC motor and a gearbox to drive the hands.
https://en.wikipedia.org/wiki/Electric_clock#Synchronous_electric_clock
Asynchronous motors are not particularly fussy about the input voltage, however they run at a more or less fixed rate, due to the way they are constructed. If you look at one of those old fashioned timer plugs, the electromechanical ones, they work the same way. So the output voltage needed to drive the motor might not need to be too precise, so if it is a little low, that may not affect the rate of the clock. A little high, might cause the coils to overheat, but a little low within reason might not have any measurable effect. Obviously if the voltage drops way too low, then there would not be enough energy to drive the motor.
The accuracy of the clock depends almost entirely on the accuracy of the main frequency, rather than its voltage.
What this means in practice is that you could probably pull an ancient 12V transformer based wall wart apart and use the transformer from it. Modern wall warts are smaller and don't use the same type of transformer, they use a switching regulator (switched mode) design.  The secondary would be fed by your switching transistor, with a current limiting resistor, and that in turn by your 555 sine wave generator. The secondary of the original transformer becomes the primary in your circuit and vice versa. Bear in mind as I said before you would produce sufficient current at approximately mains potential to give yourself a bit of a whack if you were not careful, so treat the output the same way you would a live mains circuit.
The output would be approximately correct, and probably close enough to be functional.
Edited by AndyHull
There are other ways to produce a nice clean sine wave of course.  DDS function generators pcb are cheap as chips on ebay.
https://www.ebay.co.uk/sch/i.html?_from=R40&_nkw=dds+signal+generator&_sacat=0&LH_TitleDesc=0&_sop=15
https://www.ebay.co.uk/itm/ICL8038-DDS-Signal-Generator-Module-IC-DIY-DC-12V-25V-Sine-Square-Triangle-Wave/273264014504?hash=item3f9fcdf4a8:g:yWwAAOSwQb1bF5Vm
That way you can run your clock at any speed you like... If you want to extend your lunch hour... slow it down. Time dragging in that meeting.. speed it up... ?
Armed with total control of the frequency of your "mains", you could go for the Lord Vetinari approach to time keeping.
Quote
Lord Vetinari also has a strange clock in his waiting-room. While it does keep completely accurate time overall, it sometimes ticks and tocks out of sync (example: "tick, tock ... ticktocktick, tock ...") and occasionally misses a tick or tock altogether, which has the net effect of turning one's brain "into a sort of porridge". (Feet of Clay, Going Postal). In Feet of Clay Vimes observes that it must have cost him quite a lot of money.
https://www.instructables.com/Lord-Vetinari-Clock/
The watch stopped again this morning after working fine for 2 days. I noticed the the second hand spins when I tried to adjust the time. This means that the sweep wheel click is not locking properly.
Looks like I have to do a full tear down and check the click spring.
I hate reassembling Timex Electrics and its variants. There are just so many pivots to persuade into the pivot holes. I wonder how they did it in the factory. ?
  • 4 weeks later...
I have a 40 movement and the wire is fine, but no joy on the coil. Contact pin to coil back to balance wheel is somehow gone.
I don't have anything to magnify so I can see the wires of the coil in enough detail. Anyone fix a coil before?
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
