I was wondering if it is possible to create an app that can identify an unknown movement just by taking a photo of it.
There are plant identification apps available at this present moment. I think the algorithms should be similar.
So all the software designers out there, what say you?
You mean an app when people forget how to read?
No expert here. Sure it is possible.
I tried googling some pictures of watch movements, it either bring me the same picture or of some other watches and occasionaly pots and pans instead, oh and an arse once by the name of Rolex.
Who else would have the required archive of pictures.
It would be a very useful app "Bestfit" and "Paulsons master key" are by far the best way of identifying watch movements because as anyone who has dealt with watches form the early 1900-1940 identification can be the biggest hinderance to finding parts, identifying the keyless works is the only way because we all know that a lot of  movements from that period do not have nice shiny calibre numbers engraved in prominent places to be read.
Edited by wls1971
Ranfft has an OK advanced search feature, but it's very manual and leaves a lot to be desired. With a bit of practice, it'll give you a good list of candidates which will  include your answer or at least a similar movement from the same design, if it's in his database. You can limit your search based on the bridge layout details and some features. You can't, for example, limit your search by size or by approximate year even though this info is in the db. Sometimes this can be an advantage, if for example you've got an unspecified model that is based on an earlier or different sized design. It also seems to not work well if you input too many parameters.
If you could take his database and improve the search querying and the sorting, plus add some image recognition to the movement ID scheme, it would be fun to try.
There are countless movements that get posted on here for I D many that don't have any markings at all, the only way is by looking at the keyless  work or going on line, not many on here have old reference books. I posted my Bestfit catalogues some time ago on here for people to download but even so they don't have everything. Its a must, so who ever you are make it happen.
It's almost impossible (currently) to make an app like this.  The plant finder apps or similar use "convolution neural networks" that are trained on thousands of user identified pictures of the subject.  They're particularly good at this task as the subject has a fractal nature to it.  Watch movements however aren't.  The subtle differences between the size and shape of the keyless works would be hard to match to training images.
If I were tasked to program this I'd use an "expert system".  It would require more work from the user, they'd have to measure parts etc but it would be more accurate in finding the correct movement.
For example, the app might start by asking you "Does the movement have sweep seconds", and you'd answer yes, no or unknown.  From that it could half the movements it knows about a bit like playing 20 questions.
  • 4 weeks later...
That is a good software idea especially for those amateurs like myself. On my half, if someone decides to develop such an app, I sure will take high-res photos of my watch movements in order to contribute (almost all are vintage Citizens).
    • Hello and welcome from Leeds, England.  Photos please.
    • This is the old/first(?) way for making a mainspring for an automatic. "Evolution-wise" it is an logical first step forward from a standard spring. Usually these are indeed replaced with a new spring with an integrated/fixed bridle. Lubrication as you would do with any automatic.
    • Thank you. I was informed it was a cheap worthless Lack watch from India. It’s in a small mens watch looks to be around 1930 odd   Cleaned the movement and it’s going really well. Keeps good time.  This is a great site. Mystery solved. I’m obliged.
    • I'm working on a Schild AS 1250 (a 'bumper' automatic) and it's the first time I've seen a mainspring like this. It has what looks like a regular manual-wind mainspring with a 'hook' at its outer extremity. On a manual-wind watch that 'hook' would engage with a 'hook' in the barrel wall to prevent it from rotating. However, the AS 1250's mainspring does not engage directly with the barrel but rather with a 'sliding bridle' that sits between the mainspring and the barrel wall, and evidently facilitates the slip necessary in an automatic. I'm not sure what advantage this two-piece configuration provides, but it highlights a gap (one of many) in my horological knowledge. I'm not sure if 'hook' is the correct term as used above, but please see photo below to see what I mean. Therefore, two questions please. 1. What is the proper way to lubricate a barrel from an automatic watch with a sliding bridle? My guess is the same as any automatic ms/barrel (e.g, a few dabs of braking grease on the interior barrel wall). What do the experts say? 2. I purchased a Generale Ressorts GR3472X mainspring, made for the AS 1250. It looks like the bridle is included and I don't need to salvage and re-use the old one. Is this a safe assumption? Thanks for the advice. If you have any other wisdom you'd like to share about separate sliding mainspring bridles, I would be very interested. Cheers!
