...and hi all x2
Also in the vintage lot was a Seiko 5 7009A movement with a hazed or deteriorated crystal. Anyone seen these with the silver ring on them like this? Movement itself just needs a service I think so I'm going to attempt to get it running.
Wow! My cats Rodico hairball. And I don't have a cat...
53 minutes ago, MechanicMike said:
...and hi all x2
I could be wrong, but all you need is Tension (Armoured) Ring - Standard Ring - Chrome Colour - Sternkreuz ATC
https://www.cousinsuk.com/product/standard-chrome-ringed-glass-atc
So they do exist. I was about to think it was some sort of skinny Chapter ring. In my short time doing this, never seen them before. Are they to tension the fit? Or strengthen the acrylic?  Interesting....
If there are no micro cracks in the acrylic, then polishing the crystal using Duraglit wadding usually restores them to near perfect condition......
Edited by JohnD
8 hours ago, aac58 said:
You can probably find the exact Sternkreuz crystal you need searching by the Seiko model number in this page: https://www.cousinsuk.com/category/filter/seiko-case-parts
STK didn't made dedicated crystals for all Seiko models. Only for the few ones that they deemed worth to offer an alternative, many decades ago. A generic crystal can work just fine, ordered by size.
24 minutes ago, Bodo said:
What's the case reference of the 7009?
That to allow searching the Seiko P/N on Cousins, jborel, Boley etc public references. Sometime you can find the part as NOS on Ebay etc, but often the asking price will be 2 or 3 times what the watch is worth.
The best recommendation is to just polish the crystal, which is very easy on acrylic like that
That's why I said "probably". I like the SK quality, but everyone can choose what they like, I was just trying to help. I've found a SK crystal for 90% of the Seiko's I've search for, I'm not sure the watch model in this case is 7009-340x, I really doubt it is despite it is the dial model.
Edited by aac58
Searching with Seiko case ID should be definitely your first step. Sometimes you get lucky ... and sometimes you don't.
When you don't, this page plus your measurements will find you the crystal you need:
https://www.cousinsuk.com/category/watch-glasses
7009-8810. I have them looking. No answer so far.
8 hours ago, Poljot said:
I've tried: "No items matching or containing '7009-340' are listed in our database. Please check your lookup for mistakes and re-submit."
Same answer I got. So I gave them 7009-8810. See what they say. In the meantime, I ordered a Stella Ever-tite with tension ring at 33.1mm from Esslinger and I'm polishing like crazy to see if I can get this weird white dust-like stuff off the existing crystal.
Mad polishing going on right now...
8 hours ago, MechanicMike said:
7009-8810
The Sternkreuz crystal code for that watch is XAC 311.664
Edited by aac58
  • Thanks 2
Available from 'Cousins' quite cheaply.....
  • Thanks 2
Yep. Just ordered a couple minutes ago. Thanks guys.
I am still waiting for my orders placed 5 and 3 weeks ago. Good luck!
Strange, I've always got my orders within a day or two...
oh man...
found, or finding out, this is very true, indeed. I wonder if they do this intentionally to drive us amateur hobbyists nuts? Same with their movement numbers, model numbers, and every other number combination they can think of...
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
