Hello all,
So I have a Waltham pocket watch (model 1887, estimated production in 1903) and it has trouble starting up. I can wind it up all the way and it won’t start ticking, but just tapping (what I believe is) the pallet fork It starts up. What can the issue be? I don’t know when the last service was done. I’m relatively new to watch repair and I’d like to know if this is an easy fix or something for a professional.
It could be just dried out oil and pocket lint keeping it from going. Or it could have several cracked jewels, the escapement completely out of adjustment (common on American watches, as they had easy to adjust bankings so that's what everyone tweaks when it doesn't run right), it could have worn or bent pivots, particularly on the balance staff, and probably a half dozen other things wrong with it. If you don't have any or much experience working on watches, set this one aside and find a more modern, large, Swiss movement, that's not automatic and without a date mechanism.
While it's possible that it's a simple repair, and you wouldn't be the first to dive in with such a watch, it's much better to get some experience and confidence with simpler pieces which have likely seen much less abuse in their lifetime. The old American stuff can be quite a headache, with several different versions of pivot and jewel sizes, different mainsprings, for the same base caliber. Add to that they have probably been serviced a dozen times or more in the past (it was common to have your watch serviced every year at that time), and not always sympathetically, it's a potential can of worms.
If you are really set on getting into it post some pics and ask many questions!
1 minute ago, Nucejoe said:
Sounds way out of beat. Does it run when you shake the wstch so to get the oscilator swing?
I forgot to mention that;
It does start up when you shake, but I’d say after 10 min it stops again and I’d need to repeat that, running less time than before. Eventually it does not run when shaken, and I still think that it is wound up a little.
At the time when I observed this was when it still was wound a little, and you do hear a couple swings and ticks
looking at it now, I feel like the oscillator is loose and uneven when looking at the side, it doesn’t seem to swing back and forth evenly. It’s very close to touching the metal under it, or maybe it is.
Edited by Mike7756
1 hour ago, Mike7756 said:
Hello all,
Just to remind you that we have a dedicated section where it's considered polite for new members to introduce themselves.
Loose oscilator is usually indicative of an issue with the balance pivot or jewel, pivot getting out of jewel hole, that is if there is a good jewel there, pivot might be broke or half broke or worn out too short so it can slide out of jewel hole.
Balance if unlevel wobbles and may rub on something its not suppose to.
Gently lift one side of balance wheel, with an oiler or piece of paper while you keep an eye on the pivot from side view, let us know if the pivot stays in or slides out of jewel hole. A close up side view vid of oscil running would be great. All on Mark Lovics bill.
As Jdm pointed out, introducing your self in appropriate section, telling us about your tech/horo experiences, helps us give a useful advice.
Welcome to the forum and good luck pal.
Something weird; I took the balance balance assembled out, put it back in, turned the oscillator a little and when released, it’s ticking like normal. It’s been running for about 5 minutes as of now, I’m genuinely surprised it’s running now.
does this help filter out what can be wrong?
thanks for everyone’s advice so far
5 hours ago, Nucejoe said:
So pivots are alright.
I should have said " there are pivots there",   next comes checking it in various positions.
I think I would start with a rudimentary cleaning.  Like, soak it for a couple hours in a sealed glass container of naphtha-type lighter fuel (Zippo brand will work, and will not harm the shellac on the jewels).  Don't breathe the fumes.  Hold it gently to agitate it a bit in there, VERY gently.  Then, after a while, pull it out and let it drain and dry, and see what it does.  See how it behaves.
There is a very slight chance that it may have had the residue of old whale-blubber-based  watch oil from ages past, all congealed in some out-of-the-way nook and bogging down the works.  If suddenly the movement seems less constipated, then things do get easier from there.  But not by much.  At that point, I would still say you should strip it down entirely and give it the cleaning it's not likely had in generations.  Inspect each part. Reassemble. Oil and grease as you go. That said, if the cleaning didn't help much, then at least you'll likely have stumbled upon other things in your inspection.
However, all that tear-down work can be done later if it seems a huge task to take on at the beginning.  If this pocket watch is important to you then, as Nickelsilver pointed out, you may want to come back to this one after you've had a bit of practice on some cheap or donor movements.
    • This eBay listing seems to verify that the watch disassembles as I suggested : here. The display caseback is held by the section that pushes out of the outermost rear bezel.  The movement seems to be a Ronda 1113. Best Regards, Mark
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
