Hello all, hope you are all keeping well?   Ive just cleaned and reassembled my first cylinder movement, it’s a 1900 (ish) Fontainemelon, 13 Ligne.  Can someone tell me if I should lubricate the escapement teeth please, and what should I use - I was thinking moebius 9145 Grease?  Or should they be Left clean and dry?   Thanks in advanced
Deggsie
On 12/10/2020 at 11:29 PM, nickelsilver said:
Yes lubricate the teeth, normal escapement grease is perfect 9415.
Thank you NickelSilver.   I trust your reply over one other I found, saying use vaseline and fill the hollow of the staff ?
Have a good weekend and Happy Christmas to all.
1 small dot of 9415 applied to every 3rd tooth, installed new main spring, and she started up beautifully.   Did need just a slight swing to get it going after a few clicks, but I understand this is normal as the cylinder escapement design doesn't allow for self start up like the Swiss lever design?  For a 100 year old watch I am just happy to have it ticking again, and not too concerned yet about its time keeping abiity.
Regards
Deggsie
Regards
Deggsie
I suppose the watch case is far from being air-tight. I would try to place as little oil as possible to avoid particles of dust being attracted to the surface of the escape wheel teeth. Otherwise, very soon, your watch will stop or, worse, it will turn into a "grinder" very quickly (depending on usage of course). I agree, would not be concerned about time-keeping ability. No need for the timegrapher :-). Would be nice to see a photo of your 13''' movement.
    • Thanks Mark. I think I’ll leave the beat error for now - it’s a fixed stud so I’d have to adjust the collet position.    The watch has bigger problems. On reassembly I’ve found that the hour counter reset hammer is broken - I didn’t do it, the main hammer part was just not there. Can’t easily identify a replacement part. And the subdial hands. The running seconds hand needs an extended pivot tube as the pivot is below dial level. Can’t find one of them either. I’ve found a central seconds hand that might fit it - going to have a go at cutting, filing and polishing it to make it work.
    • Good morning. I have a Caliber 11DO 17 Jewel that I utterly destroyed practicing on. My question is this. Are the 17j and 7j compatible in relation to swapping out parts such as the Wheel Train and Balance? Thank you in advance.
    • Ah ok thanks , i see thing differently now. Won't that catch the wheel rim though ?
    • No Mark it does not offend me. I think I have already started another thread on the matter before you replied. But since you are unwilling to discuss it with us, I will discontinue posting there.  Thank you for considering it though. That's a good policy to have H , you should always safeguard yourself. Knowing who you can trust and who you can't is not a permanent thing. People's values change, people change and adapt to their situations,thats just nature stepping in and running the show. Not everyone is as genuine as you are H. The new no advertising looks much better, it never bothered me much, but it still feels cleaner.  I'm pleased that your thread regarding the missing images was also returned, so thats good news as well. It appears a lot of mine have also been removed ...oh well...🤷‍♂️
    • Welcome to the forum. My guess would be to press or lift here.
