I bought this used Seiko lady's watch and it came without a battery. I bought a battery but I can't get the battery to fit, it doesn't lock into place. I thought maybe there's some part missing? Or is there a trick to it?
Firstly, make sure you have the correct size battery. Next, of you look at this battery holder, there is a fixed side and a sprung side. You have to tilt the battery at an angle and get it in under the lip of the fixed side. Then use a toothpick or plastic stick to pull back the spring and drop the battery in completely.
The drive coil is very close to the spring, so whatever you do, don't slip and damage the coil.
Also, don't use a metal tweezer to hold the new battery ( as you may have seen in an instructional video on YouTube).
On the plate or on the plastic surround there will be a mark and a number that will be the maker of the movement and the caliber of the movement from that you can identify the battery required so that you get the correct one for the movement.  If you could post the maker and caliber number it would be helpful..   The advice given by Hector is sound follow that and protect the coil and all will be well.
I forgot to mention that it should be the correct battery (TR621SW / V364). I found a PDF that says that it should correspond with the 5420A movement of the watch.
3 problems occur:
-There is no 'lip' or 'fixed side' that I can slide the battery under.
-The bottom spring is quite hard to press down, so there's a lot of tension on the battery when pushed down.
-The upper spring is way too flimsy to hold any of the tension of the bottom spring. It feels as even if I could fixate one side of the battery, the tension on the upper spring would be way too much.
Am I doing something wrong here? Or could it be possible that there's a part missing, some kind of battery cover that holds the battery down?
/Edit:
I attached the PDF regarding the movement. As far as I can determine, nothing in this PDF indicates that there's a part missing.
5420A.pdf
Edited by Mudos
3 problems occur:
Here is your battery LIP
And nothing is missing. Place the battery in, close the back cover - it will keep the battery in place. Not so good design.
Edited by Poljot
Roger that, a not so good design. It's a bit of a pain in the ass to get the back cover on with a jumpy battery, but I managed and it runs! Thanks a lot guys!
I've been in such situation once or twice - poor design. Glad to hear you managed it and your watch is running. BZ!
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
