Ok so just introduced myself and, yup, looking for help.
Over the last two days I disassembled and reassembled a practice 2824 that I purchased off the Bay for this very reason.
The good news is after a few mishaps and one episode of crawling on the floor looking for a wayward spring, I was able to complete the job.
Now, with that said, I would be really proud of my accomplishment if not for one thing and, thus the topic title. I in my rookiness managed to break the arm on the date jumper.  All else works but the date wheel won't function properly without it.
So, would anyone happen to have a spare laying around that they wouldn't mind giving up?
I'm also going to check online to purchase one but not sure of the cost and what I should spend on a cheap Chinese knockoff 2824. Matter of fact, it is identical to the one Mark didn't recommend to purchase. But, a great one to learn on IMO.
thanks in advance
Ooh-Rah!
Gerry
13 minutes ago, Poljot said:
https://www.cousinsuk.com/category/filter/eta-esa-movement-parts
Date Jumper ( 2576 ), ETA 2602
ETA26022576
In Stock
£5.96
I must be doing something wrong. I went to the page you listed and entered 2824-2 but didn't come up with the part.  I the. entered eta 62602then part number 2576 and again nothing. Where am I going wrong and thanks for the help. will be curious to se the cost to ship to the US as well
It's actually even cheaper for "2824.2:
Enter 2824, then search, then select 2824.2
or simply click on this link:
https://www.cousinsuk.com/search?SearchTerm=ETA280412576
Date Jumper ( 2576 ), ETA 2804.1
ETA280412576
In Stock
£2.95
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who?
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
