On 10/25/2022 at 11:05 PM, Hugo said:
I do not need to do bushing the wide pivot holes, the front plate hole is the most important, it needs support to relocate back to its original pivot site, I do not need n to remove the clock parts, after I wash and clean it with the special liquid, hose it off with water, all the dirt comes out, you can do it 3 times until clean under your inspection, then dry it with the hair dryer, by hand and my skill to shape the stainless steel stick, I insert it to the lower site of the oval pivot hole, 0.6mm wide stainless steel sits nicely to the position, with my skill the metal stick will support the deformed oval hole and push the pivot upward, then the gears of EW will sit nicely with the pallet, voila, it runs like a new one after 30 years run then stop, I feel very happy with my invention, I do not have any bushing machine or need to buy the expensive one, with my idea, I can fix any clocks with the trouble of worn out pivot holes, my experiment is successful, so what I know is good observation and creation will make something work, I enjoy my work!. I do not know how I can upload the video clip of my cuckoo clock in this web.
Welcome to the forum Hugo.
I would have thought that using stainless steel to correct a worn movement plate hole would now transfer the wear from the movement plate to the gear shaft pivots. It will be a much more difficult task to replace the steel shaft versus rebushing the movement plates as required.
Hi  No matter how you bodge worn pivot holes although the bodge may work there is no substitute for doing the job propely and that is either making or purchasing the correct bush and fitting it. Bodging only puts off a genuine repair and creates problems for the future, NOT reccomended.
    • Why now Mark ?  And which contact has brought you here ? People have been trying for bloody months to get hold of you for reassurance. Shite way to run a forum tbh. Seven months since you last visited. I think we all need to have a long discussion with you about what happens if anything happens to you. Please look forward to lots of questions.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
