Hi I bought a Chinese Turbillon and everything was going fine until I dropped it, after I dropped it whenever I wine it up the needle we just been really fast until there’s no more wine in it, I opened it and I poked around but did not fix it, now it’s jammed, I poked the little crab hand that goes tick-tock tick-tock, I think you call it The escapment, I was hoping someone can take it and fix it for me, it will be a great content for your video, or let me know what I can do, thanks.
my name is Ben, email me at [email protected]
thanks again
Edited by Keyba88
Spelling
That is not a tourbillon (which cost in the thousands), it's just the balance visible from the top, sometime called "open hearth".
Normally Chinese movements are not repairable but you should be able to buy a new movement for about EUR 15, and a complete watch for maybe 5 more.
13 minutes ago, vanaja76 said:
That is seagull tourbillon.
You are correct, I apologize for the confusion. Below another picture. Unfortunately that makes the situation even worse for the OP, as no parts are available anyway, and most reputable watchmaker won't work on these, so good luck repairing it.
IMHO that money would have been better spent on a quality Japanese or Swiss watch.
https://www.cousinsuk.com/product/seagull-tourbillon
    • This eBay listing seems to verify that the watch disassembles as I suggested : here. The display caseback is held by the section that pushes out of the outermost rear bezel.  The movement seems to be a Ronda 1113. Best Regards, Mark
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
