I'm a beginner.  This is a Wyler case 4115E-1162.  There are no indentations on the back nor any tool marks.  Is it a front loader?
If so will Mark's instructions for opening work https://www.youtube.com/watch?v=gGSPqtxqye4.. He pulls on the crown with a pinion remover and uses air pressure to pop the crystal.
There's also this procedure http://blog.watchdoctor.biz/2019/03/23/what-is-a-split-stem/
IMG_5979.thumb.JPG.321051f8f1c4db47176b94a29f10841f.JPGIMG_5981.thumb.JPG.a26ed680a761dfabe4d6b566b456ed59.JPGIMG_5985.thumb.JPG.e9bff36b535d36b02e340a82a802d192.JPGIMG_5986.thumb.JPG.8a298f9b4b4df418b14ea5b29efb069b.JPG
Edited by Lc130
One of the clues here is the engraving on the back perfectly centered and if it was a screw off back they never go back like that. People don't always snap the back so on perfect either.
I always like the caution that there are a feel watches that do not like the split stem separation by pulling them apart. Fortunately probably 90% of them they can be snapped off or out just fine. But there are those tiny percentage where you'll break the split stem
one of the minor things bothering me now looking at the picture it almost looks like that crystal as a tension ring inside? In other words a metal ring inside the crystal which typically you do not find on frontloading watches sort of? Omega will do that but they usually have a ring holding in the crystal assembly. Usually frontloading watches that do not have a holding ring in place expect to build a remove the crystal.
It is a front loader.  I pulled the split stem apart with a pinion puller.  I tried a crystal lift with moderate tightening which wasn't enough.  Should I tighten more or try Mark's syringe method?  I realize this is not a math question and "results may vary".
Thank you
Helpless in Maryland
Hi LC130       By all means use the syringe method the end result is the same, put a cloth over the crystal when applying the pressure via syringe.
Carl  in answer to you question  yes but not a high pressure line, all that is required is enough to pop the crystal
I'd go for the syringe method first.
If that is so I'd avoid the crystal lift for as long as possible.
I tried a bike tire pump with a ball needle, double poly bag, rubber gasket and my 9 year old putting full weight on the pump with minor leakage.  Won't budge.  I then tried the Bergeon crystal lift at about 80% to 90% full torque.  Still  nothing.  What would a real watchmaker do?
If not running 160 amplitude I'd leave it alone.
Thank you
Charlie
57 minutes ago, fixermole said:
Might that bezel need to be removed first??
Ah Ha!  That's not taught in self learning:) Yes, that did it. I pried the bezel off (now I know what a bezel is) and the crystal and movement popped out.  Thank you...now let's see if I can "service" it without killing it.
Charlie
Thankful in Maryland
Edited by Lc130
Glad I could help. I just happened to work on an old front-loading Bulova a month ago that had enough crud under the bezel and slight pry mark to realize it was removable. Even after 50-100 repairs/restorations, I learn something new with every single piece I work on. Keeps it interesting and keeps my old brain working. Cheers.
I'm not sure the percentage but 90% of the time if the stem is split there is a reason like it comes out to the front
Very common with frontloading watches use theirs of Bezel that has to come off as it's holding the crystal on. Omega does this all the time.
Hopefully a real watchmaker would know what they're doing and take off the bezel. That's another clue when used to the crystal lift and nothing was happening then obviously we were missing something. We really needed a better side view picture to see if there was a bezel or anything like a retaining ring.
I hardly every see the split stems. In this case, the case was very basic - two parts. The entire crown with outer winding step was missing. I purchased a suitable crown and the outer Stem 0.9mm, adjusted the stem length and voila! I've decided not to push it in (what if it breaks! ? ). Instead, I rotated the inner stem and the outer stem up to align "tongue and groove) and simply dropped the movement in. Once it was in, two-part stem was securely locked. Same procedure for removal - no need to pull the crown with pliers, etc. Simply remove the bezel and rotate the crown while lifting the dial until you able to pull it straight up.
As far as I know the only reason you'd ever use a split stem is if the movement is coming out the front. Because otherwise typically there would be no way to remove the stem safely.
Of course this is watch repair there's always exceptions to the rule. Seiko once made a case that they added a separate part to the movement so you can release the stem from the front side once the crystal was removed.  I have a vague memory of seeing a watch that you could remove something from the back to get to the stem release.
Then not all split stem's are separated by pulling really hard. Typically everywhere everyone tells you just pull it out and Most the time people are lucky and it's the kind of split stem that is meant to pop apart. But like the picture above that particular split stem you're supposed to slide the movement out. Mido has a split stem shaped like the picture above and definitely do not want to pop it apart. We went through this Where I work another watchmaker pulled it out damaged it attempted to tighten it and broke it. This required purchasing a used case off of eBay just to get the crown and its stem. Then the movement stem was challenging because it came in a whole bunch a variety of lengths which didn't seem to correspond to the length we had. But eventually we found the right one.
Which is why caution is always required with split stems.
I agree, but slightly disagree. Here is why: some movements could be "front loaders", BUT it doesn't mean there is no access from the back where you could safely disengage the stem from the movement. Which means you do no need a split stem. Timex M107 is one such example - I can open the back cover to visually inspect "what's going on" ? and remove the stem, but I still have to lift the crystal in order to pull the movement out of the case.
In the above example, i did not need to remove the crystal, and the "back cover" was rather a one piece movement holder with a bezel on top. It was rather the case tube design / location that called for a split-stem. Two-part case design Vs three-parts.
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
