Hey all,
Incredibly new amateur here, trying to make my own reverse movement watch. Mechanical is way beyond me so I am just going to shove a Miyota 2037 in something. I'd prefer to use a vintage mechanical watch, is that gonna work easily? If not, can I stick that movement in any old quartz watch I find, or will it only fit in watches with a similar size movement?
My related question is what's the best way to do a custom face? Hand paint it? I saw some people print basically a photo and stick it on but that sounds shoddy. I don't think I have access to any professional level dial refinishing equipment.
Thank you in advance for your help!
What you are attempting to achieve will be difficult to say the least. Quartz movements come in many sizes and not just circumference but also in height. The hands that are on the mechanical watch will almost certainly not fit the quartz movement so hands will have to be sourced. Also the new watch stem will have to be adjusted in length and have the crown fitted. To make a custom dial printing on decal paper and transferring it is the way to go but this is also troublesome.
Easiest way is to start with a watch with a 6309 mechanical movement (6309-7290 diver possibly?) and replace it with a vintage 7546 quartz movement. Everything, hands, dial, day and date wheels, stem and crown will swap straight over, but first find your watch, then a donor 7546 dress watch as a donor........good luck....
16 hours ago, DropperofSmallPieces said:
Hey all,
Hi there,
For an amateur "watchmaker" you have very ambitious plans! ?
It's possible - why not? But why not to simply fix one of the mechanical watches to get an idea what is involved in such transition?
Pick one with broken or missing hands, a missing crown, broken crystal, rusty winding stem ? - the one you can get for almost FREE. Then download the parts list, TIs, take measurements, locate spare parts, etc. This way you will quickly learn how-to select the replacement Hands, how to adjust the Stem and select the right winding crown for your case / tube, how to install the crystal and choose one, etc.
After that, when you try to convert your another cheap mechanical watch to "Perpetuum Mobile" aka Quartz ?, you will select a good candidate:
- Hour and Minute Hands only - to somewhat simplify your task
- slim case design as your Quartz movement will be no doubt thinner than Mechanical movement
- your Quartz movement Hour Wheel Height and Dia should meet your Mechanical watch hands measurements
- you may get away with cutting the dial posts and using double sided adhesive tape, etc to fit the old dial
- and almost guarantied that you will have to make or adjust your quartz movement plastic holder to secure the movement inside the case.
And this is NOT the complete list of challenges.
Good luck (you will need it)!
Interesting answers?
The reason I started off with what I said was that this is standard or was standard operating procedure at one time. I've attended at least one lecture where it was explained how it's done. Then I was pretty sure there was at least one book and sure enough my memories right there is a book I'm sure it did not cost this when it came. Amazon is interesting for the price of the books but this will let you see the book is available.
At the time when this was more common is very common to do it with ladies watches because now you'd end up with a watch that they didn't have to wind up every day.
The best would be to get the book. Simplistically need to find a quartz movement of similar size I would pick a modern quartz movement if you going to keep with vintage than stay with the mechanical watch you have. Because otherwise a vintage quartz watch movement brings up problems of its own. you need to find a quartz watch of similar size or smaller. Then they used to make a product zero idea whether it's available anymore that would be used to make a retaining ring to the hold the movement in place. Then you don't need a new dial use the old one if you notice on the cover of the book you will see the dial foot soldering machine. In other words you break your dial feet off to put new. Then there is way more choice of hands now's they won't look quite as bad as they used to because they came in limited choices.
Then towards the end of my answer L is like to reread the original question the make sure that I getting the answer right and I'm confused? The word reverse means backwards typically?
Then the title mechanical the quartz conversion my answer would be corrected but if I rephrase your question of you would like to make a reverse running watch then my answer is wrong?
Then as a bonus of bizarreness of my misunderstanding what makes you think that quartz watches can run backwards? By the way yes they can but and I'm the skip over that part it ranges from very easy to work is required.
https://www.amazon.com/Quartz-Watch-Retrofitting-Wesley-Door/dp/B000JJ1SS0
The Miyota 2037 movement runs in reverse, that is to say counterclockwise. It's the same as the ultra-common 2035 movement, just runs the opposite way. Cool book btw, thanks for linking to it. Going by people answers I think mechanical to quartz is beyond me. But I'm just going to find a watch that already has a 2035 quartz movement and replace it with the 2037, that should be pretty simple. Then I just need to redo the face somehow.
If you don't want to play with the dial there's another option? Find a watch that doesn't have numbers. There's a lot of dials that either have no markers at all other than something at 12 o'clock or they have markers but no numbers that would work fine. Otherwise do a search on this group there are people working on dials they might be helpful.
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
