Hello Community,
I am currently working on a Miyota 8200 and I am confused that they oil the third wheel with 9010 instead of D5.
Is it related to the fact that the third wheel drives the second shaft ?
I'll attach a photo.
Happy Holidays and Merry Christmas to you all !
@Rafael thank you. But why ?
Normally (Unitas 649x) you oil the third wheel jewels with D5. Why here with 9010 ?
Can you tell me the reason?
@Watchtime
this is how i learned it. And the third wheel has a high pressure, so it would be oiled with D5 ?
Or is this construction the reason why it has a low pressure ?
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you!
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
    • This eBay listing seems to verify that the watch disassembles as I suggested : here. The display caseback is held by the section that pushes out of the outermost rear bezel.  The movement seems to be a Ronda 1113. Best Regards, Mark
