I have a Looking Thomas Earnshaw - Longitude - ES-0025-05 and as you can see from the photo below the hand on the month dial has come off. In order to put it back on I need to remove the movement / dial from the case but I cannot seem to remove the crown / stem in order to do so. Any ideas?
Edited by chatlourd
prefix update
Use tweezers or a sharp peg-wood, etc to push and hold where red arrow shows. Hold it down while pulling out the crown with the stem.
THANK YOU ! IT WORKED LIKE A CHARM !
Cheers! ?
Be extra careful - do not touch the coil.
Edited by Poljot
Be carefull when putting back the hand, you can use the back of a piece of pegwood to press the hand gently, not to hard,  on the pivot. if you press too hard, you can damage the tube of the hand.
