14 minutes ago, HectorLooi said:
Do you have a photo of that piece of brass.
Very observant!
15 minutes ago, HectorLooi said:
I've come across some Russian watches with a brass shim placed under the balance cock to raise the height to give the correct amount of end shake.
I'd say 90 % of all Vostok 24XX calibers I've serviced have had at least one brass shim and sometimes two stacked together under the balance cock. So yes, very likely the problem.
17 minutes ago, HectorLooi said:
If the shim has fallen out, that would explain why the balance wheel is tight.
Indeed!
2 hours ago, HectorLooi said:
Do you have a photo of that piece of brass. I've come across some Russian watches with a brass shim placed under the balance cock to raise the height to give the correct amount of end shake. If the shim has fallen out, that would explain why the balance wheel is tight.
Sadly i've lost that small piece, but i can assure you it was the broken off part from the fork holding down the 2 gears connected to the rotor and not the shim from the balance cock
Edited by Ch3sm0829
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
