Anniversary Clock Running to Fast
Konrad
Hi all and a merry xmas. I have a Kern anniversary clock which I have restored. The clock runs well however runs extremely fast despite turning the adjustment +/- clockwise fully. I have had a look at past forums and note that it might possibly be an incorrect sized torsion spring/wire. I believe the current wire in the clock has been replaced by someone previously based on finger prints found on covering sleeve. The pendulum weights (4) turn approximately 120 degrees. Is anyone able to advise if I am correct or an alternative idea to correct problem? Would appreciate any help including the correct sized spring and where to find/buy them. Many thanks for any help given2130923817_DSCN06311.thumb.JPG.32f25583dcd44cd5a975fc1c93f1c92b.JPG1790354123_DSCN06301.thumb.JPG.36a4fb5000f0a5afb9160be17805180c.JPG.
Hi If you can beg borrow or buy Charles Terwilligers book, the 10th edition  which is the bible on 400 day clocks, there is all the information you require, or as an alternative post a full picture of the back plate and members will be able to Identify the model and the spring type you require.
As Old Hippy said  the condition and length of the spring and its thickness and the positioning of the fork are critical to the operation              Happy New Year       all the best.
Oldhippy is correct it will almost certainly be a suspension spring fault. Too strong or too weak results in running out of adjustment. It is possible to thin the spring if careful. The method is to lay the spring on a flat surface and carefully stroke the spring with a fine Emery ie 2000 grit to remove material. BUT you must not kink the spring in anyway.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
