Hi All,
My buddy at work just got his grandfathers old 1947 Gruen very thin watch for Christmas.  It has the caliber 385 movement in it.  I don't think the watch has been serviced in years.  It is a manual wind with sub seconds.  He said he wound the watch and it was working for a couple of days.  Now it does not run though.  The problem with the watch now is that when you wind it, the mainspring doesn't seem to me winding, the crown spins and spins without any increase in tension.  You can hear the clic clicking away so I assume that the keyless works are connected all the way to the ratchet wheel.  So we assumed broken mainspring.
The unusual thing is that when you pull the crown out into setting position and put any forward motion thus advancing the time or any forward pressure without advancing the time, the watch starts to run.   I'm stumped.  If I assume that the mainspring is broken, how is there any power on the watch and what is this phenomenon of the watch not running in the winding position but running when in the set position with forward motion or pressure on the crown?
Would greatly appreciate your help on this.
Regards,
Jeffrey
It does sound like a broken mainspring.
When you set the time you are slipping a friction clutch that is directly mounted to the center wheel of the watch- which is also what directly receives the power from the mainspring barrel. So when you set the hands forward you are supplying forward power/ motion to the gear train, and this is running the watch. Totally normal.
If of any interest; that "friction clutch" is called the "cannon pinion", and when setting the time its slipping action on the center wheel arbor isn't perfect so it exerts some force on the center wheel which is part of the gear train (as @nickelsilver already explained).
Thats not as bad as my watch, runs backward when put in any backward motion.
Ouch! ? Too little grease on the center wheel arbor?
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
