Happy Holidays everyone!
Nearing the finish line, servicing an AS 1803 movement, I decided to clean and oil the lower shock jewel.  Laziness (or ambition?) caused me to attempt this while keeping the date wheel installed.  Approaching the spring from an awkward angle with my tweezers, I squeezed, and the spring broke.  Am I to blame?  I think so.  I didn't know these were so delicate.
This will be an expensive mistake, I think, and I should take the chance to add a 2021 resolution to my list.  Cost of correct incabloc springs.  Seems I will need to buy a jeweling tool to push on the shock setting from the movement?  Probably cheaper to buy a whole donor movement...:)
Sad:
PXL_20201230_075810100._exported_1199_1609315162130.thumb.jpg.0f309265e43bc0d8456c411ba0d104f0.jpg
PXL_20201230_085607700._exported_1665_1609318632456.jpg.be5b78c9b00fcd46fcfd0ed5b0323d11.jpg
Edited by gaber
picture of setting, my own solution
All you need is a spring,  housing for jewel setting can be pushed out with a wooden stick( inner side of mainplate)  slide the spring in and lock it, replace ** , finally put the jewels back in.
Sounds like you simulatanously squeeze both prongs of the lyre spring in tweezers, slide each prong into the groove one at a time.
Replace**,   Use a FLAT end staking punch to push the housing back in or any  flat surface metal stick would work as long as its diameter is larger than that of the housing.
I would buy a set of five of the spring you need. The packs cost 5.50 GBP. If you can steal one from a donor, that's even cheaper. Not sure if you have to move the setting to fit it though. In the past I've been able to do without.
Edited by Klassiker
According to ofrei.com incabloc 975.03 is the correct part for this movement, and I do see that Cousins carries it, but I might just buy a donor as it is not so expensive.
Thanks, Joe, I'll give this a try.  To clarify, are you saying that the stick is applied on the inner side, so that the housing comes out on the dial side?  If this is the case, I suppose it needs only to be pushed a bit out to access the groove to install the replacement spring.  Also, I assume the housing needs to be replaced very closely to its original depth, so as not to affect the end shake of the balance, correct?
You have correctly understood my broken English on all counts.
Yes the housing is to be pushed out as you say above and as much as you say, it poping out would not trigger world war three either.
You are very correct that you can move the jewel for correct end shake so far as the staff length is concerned( not to compensate for worn short pivot)  ideally you want the housing positioned  to cover the groove inside the hole in mainplate, so as to prevernt the lyre spring from sliding out of the groove.
Wooden stick so not to scartch the housing, flat end so not to bend concave the falt face of the housing. Push on the outer edge of the housing at multiple points, not the middle.
When the housing is inserted , it might sit flush level with the mainplate, or stand proud a little, in case it is to be pushed in deep in the hole, I use a punch of smaller diameter or stick and push on the rim of the housing only, so to avoid pushing on the spring.
I think you got the picture right and will have success.
Good luck.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
