Hi.   I have a vintage roamer waterproof case type.  It opens from the bottom.  Snap type caseback. It has a split-stem.   And i cleaned it and all.   But when i tried to close the case.  It's so loose that the case back holding the movement doesn't close with the top part of the case.   Also there's this metal ring.  Which i don't know where that should go.
Please help me out.
Thanks in advance
If you examine the ring closely its a crystal tension ring that someone just rigged.
The movement fits inside the back plate (like you show in picture)over which fits the bezel.
Roamer anifibio it is, right?  One of my favourate brands, the movement is in-house made some MST caliber, Swiss brevet.
Regs joe
Hi.   The model number inside is 130 430.  I also need a replacement glass.  If the ring is crystal tension ring.  Then how to put it back.
According to the roamer parts manual.  The glass is x7130.  I don't know which glass to buy.  Can someone search this up and tell the link please.   I'm very confused.  Too many options on cousins but i don't know which one to buy.  Step glass or no step glass?
Thanks again
Thanks again
Unfortunately this part is listed as obsolete, but you have a good description to continue your search:
Roamer X7130 Glass (29.20 x 0.61 x 5.10mm)
MSTX7130
https://www.cousinsuk.com/product/roamer-glasses-by-part-number?code=MSTX7130
Yes.   I saw that.   But is there anything in cousins inventory that will fit.   As the glass is cracked of old age.  And i don't know if it's stepped glass or not
Crystal tension ring is not a technical neccessity, it just aestetic, just to sit there and look pretty, so you can even use a cheap generic crystal.
You can push the crystal out and measure its diameter and height, should you choose a crystal with tension ring you then need a crystal press tool as the ring jumps out if you tried installing with regulare claw tool.
I would just throw this broken ring away, in the very unlinkely event the movement is loose inside the case, you might use a rubber O-ring gasket to take any slack out.
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
