Happy New Year guys and ladies!!! Quick question.  On the cap jewels, does the flat side face up or the concave side. Reason I'm asking tried replace cap jewel on one of the wheels,  well the the retainer spring will lock in but will not lock in will concave facing up. Im working on a ST 36 movement.  This is my first movement project,  and well learning alot lol. I've disassembled movement cleaned and oiled. After springing jewels, shock springs , etc. Im amazed how far these tiny parts fly lol! Im so ready to complete this build. Thank you all.
Verify that Cap Jewel is Flat side Down and set correctly (flat) inside the jewel holder. If it's positioned even under slight angle you will have issues with the locking spring.
Flat side is to face the pivot.
In case pivot is worn and short so PIVOT SHOULDER rubs on the housing, your choices are
-To replace the staff
- Replace the balance complete
- Face the dome side to the pivot so to compensate for short pivot. This is when the first two choice are not available to you, a draw back to this is oil will not stay on top of the dome, so you might give it an epilame treatment.
1 hour ago, watchweasol said:
The usual convention is the flat side down, although some have been found done side down to compensate for excess end shake   Attached picture, Is this the type.
Yes this is exactly the one. Thank you very much, I surely appreciate it!
Ah this may my issue. I've been having a heck of a time getting this movement in its case and on my wrist. I mean things like lost cap jewels, broken mainstring,  now broken hair spring. I guess it's all in the learning process.
I forgot to mention, the jewels in question are for the first wheel. I may remove the wheel bridge and inspect the pinion on the first wheel, I can't actually see the pivot on the dial side stick through it respective guide. I can wind my spring, but have to slight nudge the 1st wheel to get it to spin.
I'm a complete amateur so please excess my lack terminology and written descriptions I may post. But I thank all of you that help and add their knowledge and advice.
Thank you sir!!! Greatly and humbly appreciate your time and advise.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
