When it was going so well..... broken screw!
Robbie010
All seemed to be going swimmingly..... the dubois depraz module went back together (with a few hiccups along the way) and seemed to be functioning well..... left it overnight and when I came back to it a screw top has pinged off ?
Looking online there are a number of extractor tools, the Bergeon one coming in at £100+ with the various bits or the Chinese ones at around £30 - £40 with a load of bits included!
I think I already know the answer to this question but I’ll ask it anyway..... am I best forking out the £100+ for the branded tool or has anyone had any positive experience with the generic Chinese tools!??
I believe that there have been some comments on here in the past regarding the Chinese offering which suggested that the two bore axes didn't line up very well.
However, before you part with your cash, have you tried using a fine pointed needle to rotate the broken part of the screw out? If you have access to both ends of the screw (which you must have in order to use the extractors anyway) then the screw shaft isn't tight against anything once the head has sheared off, which means that there is a good chance that threaded part will just unscrew, and a fine needle point should be able to get enough purchase in the broken top of the shaft to turn it.
I have the Bergeon extractor, an old one so "old school quality", I don't think it's ever actually worked for me. Also, the standard tips are too big for most modern stuff. I agree with Marc, try backing it out. Very often the remaining bit is actually loose once the head comes off.
If it's tight, I've had better luck than the Bergeon tool using a jeweling tool, using a pusher and stump that effectively do the same thing, clamp the screw by its ends, then swing the plate/ part around. Often have to make up pusher and or stump to fit, but it's a few minutes work.
In the really bad cases the part goes on the jig boring machine and gets milled out. Yuck.
I do own a Bergeron screw extractor and I have only used it twice over a number of years. It worked both times with no effort. It depends where the broken screw is it might be possible drill a hole in its middle and twist out with a small broach. Before I purchased the screw extractor I did try the Alum trick but I had no success hence the purchase.
Horetec has a driver but instead of the usual screwdriver blades for bands and such, they blades that have been sharpened with individual sharp teeth on the diameter of the blade, with the thought of them "biting" into the broken part. Thought of getting one myself. Don't have the link handy tho sorry.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
