Demagnetizer Recommendations
Don
I've got a movement that I think is magnetized. The hairspring coils are sticking and it makes a compass needle jump when placed over it. Here's a pic of the timer reading:
I've watched Mark's videos and so I'm shopping for a demagnetizer. I'm looking at the Etic for about $80 shipped, the similar C&H model for about $30 shipped, the generic clones for $10 or so from China, this bad boy from Amazon (too heavy duity?) and some vintage Vigor demagnetizers. I'm a little (a lot) tool nutty and I hate buying really cheap and then spending again for one that works. Any recommendations?
Also, just for fun I was playing with the super slow speed function on my camera last night and made this video. Not great quality, but may be of interest.
https://youtu.be/JpLEB0kiHw0
Thanks,
Don
If you can afford the Etic, then go for it - I melted mine by leaving it plugged in and mistakingly setting a book on top of it which pressed the button down :D
I since purchased one of the Chinese ones to see what it was like and it works just fine.
The Elma I have in my video is an electronic one and it is good but IMO seems to do no better than the cheap chinese one, it is just very convenient to use.
I was going to get one of the Chinese ones as my next tool purchase.  The 3 Dumont tweezers I got from my watchmaker desk purchase are all magnetized so I defiantly want to fix that so I can start using those great tweezers.
Thanks for the input Mark. I got the Etic for about $68 shipped. Assuming it's in stock, I'll have it tomorrow or the next day. I'll keep it away from books and I'll update this post when I get to use it. :D
Blake, how's the bench? Did you re-stain it?
I'm leaving the stain till the end.  I have one of the drawer fronts that is trashed and another that has fallen apart and will need a few pieces replaced.  I got my father-in-law's router for this but need to buy the correct bits for the recessed drawer pulls.  Once I have those sorted I want to replicate the rails that would have originally be on the sides an back to hopefully catch pinging parts then move on with the stain.
Nice! I hope you'll post the finished piece when you're done.
Hi Roger, that was the first type that I purchased. It's very easy to use, hold the watch over the flat part above the switch and light, press and hold the button while slowly moving the watch away from the demagnetiser to a distance of about 800mm, then release the switch.
Sometimes you have to repeat it a couple times to get the correct result, but it does work.
Probably where i did wrong . I didn't now i needed to remove it slowly from the demagnitiser . I do now .
I bought this one from eBay - item 330738537038 (more in stock) from HK.
It is half the price of the identical item from Cousins and one-tenth that of the seemingly equivalent Bergeon 2321.
One minor problem is that to follow these instructions from Bergeon and Cousins you need three hands:
Slowly pass the piece to be demagnitized through the apparatus, and take it out the other side.
Repeat the operation several times, always in the same direction.
Press the button during the entire operation.
The only solution for me is to fix the item to a long  strip of cardboard and then pull it from one side to the other through the hole while pressing the button, ending up about one meter away. This works a treat. The great advantage over the flat-bed type is that it can demag much larger items
Edited by cdjswiss
  • 1 year later...
I am working with an NMR spectrometer which is 94000 Gauss :) Sure my watch was magnetized, it even stopped once i forgot to take off before going close to the magnet. Since i had a suitable transformer and remaining wire from generator rewireing decided to put together a demagnetizer yesterday. Used the middle of an empty bottle as the coil shape, it is big enough for all sized watches, even for my Roskopf pocket watch :) The 230V/60Hz main current is transformed to 12V/60Hz with a toroid transformer. The wire is 0.7mm in diameter and four layers were wound. It is connected directly to the transformer... well, burned some 800mA fuses when connected to quickly with a switch :) but working fine with a crocodile forceps. The copper layer under it is for cooling. It is heating up over 60 Celsius in 30 seconds.
Before demagnetization the gauss meter (android app) shows up to 3 Gauss.
The peak is only 0.34 Gauss after demagnetization :) The rate increased by ~10 s/d, amplitude is the same and it is more stable in the different positions.
Finally demagnetized all of my steel tools. Never again sticky screws :)
Edited by szbalogh
de  magnetize /  de GAUSS :  I have a couple old watchmakers de magnetizers.  there is a button to  hold down  when  passing AN   ITEM  thru  (in and out)  of the coil.   this  means  there is  no  power on when  left un attended.    I  like that  GAUSS  meter.  vlnn
21 hours ago, oldhippy said:
You are right, the beat error increased a bit from around 0.3 to 0.5 - 0.6ms. I will introduce some light bulbs to the high Voltage side to reduce the power.
The magnetic sensor in my smartphone is on the top right corner of the display. Google says that usually it is in the top left corner. You need to place the watch directly over the sensor to measure this small fields.
Edited by szbalogh
the proper tool  is  a  '"watchmakers  de magnetizer"  you  don't have to  worry about too strong a  magnetic field.  the  use of it is a separate subject,  as is  the  deturming if a watch is magnetized.   check out De Carle's book.
Added a 60W bulb standing lamp to the 220V circuit which i was using anyway nest to my bench. Power reduced to around half and now it is heating slow but its effective like before. Tested with a screwdriver magnetized by a neodymium magnet :)
i love the video that you made. it's really the first time i've seen the escape wheel in full arc. is that the typical amout of "swing" that an escape wheel has? i thought that they had an almost full turn, but this one is about 270 degrees or so.
  • 4 months later...
Hi guys, I was just wondering if you could give me your opinion on which demagnetizer to go for. I am a hobbyist and i just service my own watches and any other movements i come across.
The options are all from cousins website and range from £2 to £160.
The cousins cube is £2 will this do the job? I guess you just slide the parts through it and job done?
Etic swiss is £30 and is mains powered.
Greiner and Elma also do demagnetizers around the £160 mark.
So, id really like your opinions, can i do this on the cheap at £2 or is it going to be wise to spend a little more?
You need a mains powered unit to generate an alternating magnetic field to be of any use in watch repair work.
Check out eBay and you will find many Asian versions of the Etic unit (which is almost certainly of Asian origin itself) for anything between £5 and £25. Since all it is is a coil and a switch there is little that can go wrong.
I have two units, an ancient pass through type that came in a job lot of tools and is great, and an Etic type that I paid about £7 for. They work as well as each other.
    • I have been recently servicing an Omega 3220A chronograph movement which uses a Dubois Depraz 2000 chrono module.  This has been quite a time consuming project, not necessarily difficult but with lots of steps.  Working on the chrono module is like working on the love child of a hugely complex keyless works and a Timex pin pallet movement. I do have access to a couple of Omega tech sheets and a couple of relevant Youtube videos (including Mark Lovick's Breitling series) so I feel confident that I have all of the required information. The 'tractor' movement (effectively an ETA 2892) had no issues with obtaining 300 degree amplitude dial up / dial down and maybe a spread of 7 seconds across all of the positions.  I serviced the chrono module and when reinstalling it, this brought the amplitude down to about 260 degress with the chrono stopped and 200 with it running.  The Omega specification states that the chrono running should see the amplitude drop by no more than 40 degrees (from, I am guessing, the assembled amplitude i.e. chrono stopped rather than just the bare tractor movement). Obviously this isn't good enough. I am going to have to redo the chrono module again.  Where I suspect I have a problem is inconsistent / over oiling of pivots.  For some reason the Omega technical guide states to apply oil to the bottom pivot of each wheel and then place in the jeweled base plate.  In practice, I managed to smear oil on the horizontal base of the wheel which would be smeared over the outside face of the jewel.  This also wouldn't be helped by dragging the wheel around trying to get the lower pivots to engage in the the jewel.  When I watch Mark service a similar Breitling chrono with DD module, he also oils the bottom pivots and installs the wheels (obviously doing a better job than me!).  My question is, why can't I install the wheels dry and the oil the jewel on the other side of the base plate in the conventional way? The top pivots are oiled through the jewels in the conventional way, so why would the lower pivots be any different? Looking at the those jewels (picture below an example from a different movement) it looks like there isn't an oil well in the outside surface of the jewel around the pivot, so perhaps I would be better applying a drop of oil directly to the jewel hole before installing the wheel?  Perhaps the jewels have different arrangement to conventional jewels because the outside face is installed against the dial side of the tractor movement and we don't want to risk oil migrating from the module to the movement. There are also a couple of friction springs that may have an impact on amplitude, I will recheck their pre-load but these should be OK.  Is there anything else I should look at as a source of friction in the DD module?
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
