This may be kind of a dumb question, but  here goes. Im working on a Russian Vostok that I picked up cheap on ebay. It had a broken stem and was super dirty with old oil. Other than a missing bridge screw and the broken stem, I didnt see anything that jumped out at me while disassembling and reassembling. Everything seems back in order and I can wind it, with new stem. But, there seems to be no transfer of power from main spring to main wheel. I checked that everything moved freely while assembling and lubing.
Are there any tests or procedures that I can do to determine the cause of the issue? Or any suggestion on what may be the culprit?
Btw, i am a novice watch tinkerer, but have been tinkering for a while with some success. Troubleshooting is not my strong point. Thats why im here. Lol
Thanks in advance,
Brian
I don't quite understand this. You can wind the mainspring but there is no power to the wheel train?
If you remove the pallet fork and wind it, do the wheels spin freely?
Are you sure mainspring is not broken, turn the barrel to supply manual power to it , use a wooded stick. also test gears for freedom of move apply torque to the spokes.
You should see your opportunity to conduct most tests before and during disassembly.
Regs
Joe
Thanks Hector and Joe.
I think I was getting a little ahead of myself. I had the mainspring apart and all looked good. In fact, I had it wound up the wrong way in the barrel and had to reverse it. It is holding power, but something else is hanging up. I will test a little more thoroughly. Its got to be something simple. I have not yet had a chance to remove the pallet fork. That will be the first thing I try.
Everything was spining freely during teardown. Thats kind of why Im confused as to what could be wrong. Has to be something I did. Lol
Thanks again guys,
Brian
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
    • Hi there Stoller,   Caliber is generally stamped under the balance or thereabouts.  Caliber can't neccessarily be identified by bridge layout. Regs
    • Unless you've got any better suggestions Isn't that what this forum is about? It still depends what state the balance is in to start with. Edit You see, it's things like this that really wind me up and make me wonder if it's worth even sticking around, think I'll say goodnight and keep well
