So I've gone and done it.  This morning while removing the jewels from the balance bridge on my Favre-Leuba 253 I broke one of the legs/arms off of the shock spring.  Not sure if I was just ham handed or if it was brittle as I had no such problem with the bottom spring on the main plate.
Another research project ensues.....
Based on this info:
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&Favre-Leuba_253
I see KIF-Satellor on the page.  A clue a clue!
A few googles later and I end up on this page:
http://www.boley.de/en/shop/4802.kif-satellor
Getting warmer.  The shape of these springs is definitely correct.
Any idea if these are the only Satellor sizes?  I can't really measure mine as one entire side is broken off and I doubt I could eyeball the difference between 1.9 mm and 1.6 mm.
Looking around at suppliers, it looks like my only options for this part are CasKer or Otto Frei/Jules Borel in the U.S.  I've called Jules Borel in the past and they said I had to be either AWCI certified or be a student in an AWCI certified school to order from them.  Are all you guys who order from JB AWCI certified or is there some trick?
CasKer has them in stock at twice the price of JB.  I haven't tried to order from CasKer yet,  not sure if they have the same stringent requirements as JB.
I can always go for Cousins, but I hate the wait,  plus when looking for the 4-2 Cousins says it is obsolete and suggests a 3-2,3-8  not sure if those are even Satellor?
Any advice?
Hello Icius,
Welcome to the forum. The KIF is a difficult spring to work with in every way possible. I had a similar problem witb the KIF trior and elastors-they break quite easily and putting them in is a hassle. I finally had to buy the little tools that are specially made for the triors because I kept losing them! For your issue on ordering--I am guessing you are in the U.K.? I would suggest you order BOTH 1.6 and 1.9 if you don't know the size. I could order for you from J Borel but I live in Brooklyn and the shipping would take time. I've had help on this very topic from a member here (RustyColt) that lives in Canada, but either way it will take time for shipping. Cousins is a great material house, but if they don't have  the exact size maybe you can call them and ask them if the know for certain that the suggested equivalent will fit? These springs have very little "wiggle-room" and the size must be exact or close to it. I tried substitution of KIF elastor in two Bulovas and it didn't work--They looked identical but one had shoter legs than the other and it broke. I can order from J borel if you have the part number...
J
Edited by noirrac1j
J,
Don't get me started on Triors, let's just say my first trior experience had me on my hands and knees with a flashlight and optivisor for about an hour :)
I'm actually in the U.S. ,  close to Pittsburgh, PA so if I shout loud enough you can hear me right?
I really appreciate the offer of ordering from J Borel.  Their part numbers are:
4-3:  400/1512 - $4.50
4-2:  400/1369 - $3.00
Not sure how you want to handle payment and such?  Send me a PM?
I priced a number of parts from CasKers and their prices really seem outlandish.
Thanks again for your help!
Just an update, thanks to noirrac1j I got the KIF Satellor spring I needed for this watch.
Just so that it is on the internet, indexed and searchable for all time:
The Favre-Leuba 253 Movement takes a KIF 4-3 Satellor spring for the top balance jewel.
Replacing this spring was super easy thanks to the clingwrap method.
    • This will be my first crystal replacement, I have a press, but looking at the watch I wonder if I might need a bezel tool also. Any and all help appreciated.
    • I'm not entirely sure you fully understand what he's doing in the video. For one thing he's giving examples of things like about 16 minutes he talks about opening up the regulator just a little bit. Opening up the regulator slows the watch down to compensate for that he moves the regulator fast and now it's keeping time again but the regulator pins are too far apart. I have an image down below on top of it shows the effect of regulator pins and amplitude. If the regulator pins are farther apart than the example down below then at a higher amplitude timekeeping will be much worse. Why the regulator pins are supposed to be adjusted as an average rule approximately twice the thickness of the mainspring itself. In other words if you look at the spacing it have one half of the hairspring thickness on either side of the hairspring itself. There is like he talks about the video a little bit of adjustment here and there. So in his example where he opened them up it will really dramatically screw up timekeeping based on amplitude. Then when you get to the 20 some minutes like you say he is adjusting the regulator pins closer together to get a more even timekeeping based on amplitude and amplitude changes are caused by going to various positions. Then and the other example of the image down below regulator pins too far apart and they hairspring is not centered and look what that does the timekeeping. So hairspring is supposed to be centered regulator pins are supposed to properly spaced. Then you get reasonably even timekeeping like it shows in the upper image. It's not like we're regulating out positional errors like poising errors because that's something entirely different.   In the part number above and in the video both of you left off details. I which version of either of your watches I will just make you's timing specifications for your watch down below may specify how you're supposed to do it other words you wind up the watch fully wound up you wait 10 to 60 minutes in the four positions it should be within 60 seconds. Yes it can be closer but you may not actually get zero.     Now let's compare with the 2892 and see where we might have a discrepancy. First off we have a problem of which one is a using did he use the chronometer grade 1 or the top grade or what?  None is basically just much tighter timing tolerances. So when he's using an example watch conceivably might be a chronometer grade watch then things are going to be much more  perfect than what you're going to see.       NH35_TG.pdf ETA 2892-A2 Manufacturing info.pdf
    • Note the 8992 is 850 pounds for a liter. I think this is really for industrial settings like they say, where it would be used as a final bath in a 20,000 buck cleaning machine. I use the 8981.   That is excellent- I don't often get to see a serviced watch 5 years later, but when I do I expect to see pretty much the same oiling on the balance jewels as when it went out. I think at that area, being essentially sealed, it really should remain fairly pristine for likely 10 years. It's why some makers go to the trouble to use cap jewels on the escape wheel as well- not so much for friction reduction, but to keep the oil longer where it really counts.
    • I own too many WW lathes, as well as two sherline lathes and a sherline mill with a cnc indexing rotary table. The majority of my experience is using the WW lathes to make staffs, screws, and stems. Recently, I have been experimenting making a pinion on the mill using the indexing table. It works. So, if you want to cut wheels, get the Sherline mill and indexing table...imho
    • That's strange. I re-serviced a couple of watches after about 4-5 years and there looked to be no loss of oil. These are watches I very rarely wear, and I probably over-oiled a bit back then.
