Hi everyone
Thanks in advance for the welcome.  This is new territory for me and looking forward to learning.
Happy new year and best wishes!
    • Hi watchweasol, yes that is a way of doing it I suppose, I have a pair of mainspring hole making pliers on their way off eBay, the ones with the different shaped punches. I may be able to use them to make a hook.
    • Hello everyone, Glad to be here.
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
