Hello,
I am a newbie here, so I apologize for my newbie question.
I have a "vintage" Seiko dress design 7T32 quartz chrono alarm - watch has not run in 8 years, last used crown screw broke/fell off.
As it is "vintage" and my wedding gift, I have nosalgic reasons to return it somehow to working condition.
Question : Is there an alternate movement, either quartz or automatic, that would fit in the 7T32 case - 30mm ?
At the least, I am interested to know what available movement will work to replace the original 7T32-7C69 (blue on gold)
Thanks for your advice!
P.Fitzgibbons
Hi  The shiojiri Y182 will fit but they are not easily found. Donor watches are Yema,    Pulsar Y182B,  there will be others I am sure but not cheap.  Other members will most likely know of a few more.
There is a Orient movement too, HFA00, but it's even less common than the Y182B.  The 7T42B will also fit and work fine too, but it's less common than the 7T32B.
Physically, many other Seiko movements, 7T52, 7T34, etc. are the same size and shape.  But the hands and date are different, so they wouldn't make sense with your dial.
So how frakenwatch do you want to go?  I think ANY 7Txx movement can fit in the case.  The part that matters is getting a spacer ring that fits the movement to the case's diameter.  But this is just a plastic ring and one you have could probably be easily modified to fit another 7Txx.  The two crown and three pusher layout of the 7T32 is less common.  If the donor movement has a different arraignment, it will be rather ugly to say the least.  But at least the main crown will always be there at 3 o'clock so the time can be set!
The dial itself needs to fit the case and there is usually a bezel ring meant to fit the dial and case.  Thickness is an issue too with the bezel ring fitting the case.  However, these don't really come in that many different sizes.
But you might be able to repair your watch.  If the circuit board has not been damaged then the remaining parts are attainable.  The exact correct crown might not be available, but one that fits and looks close will be.
And if the circuit board is damaged, then you can buy a working watch to get the movement or board.  That's much easier than trying to fit a 7T92 into your case and will have a better outcome.
  • 2 years later...
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
