Hi all just wondering if anyone may be able to help? the watch in the image is a Next one that was purchased for my mum with another two to other family members who are no longer with us. She thought it was just requiring a battery, however once changed it still does not work. I do not have the facilities to test quartz movements and was wondering if it would be possible to purchased another quartz movement and fit the old dial and hands? If so, where and which one would be suitable? btw the movement diameter is 17.5mm
Regards Jasp
Regards Jasp
Finding a new Miyota quartz movement should be easy. Just lift that white plastic ring and try to find the model number of your movement.
It could be this one:
Movement, Miyota 2025
2025M
Add to Favourites
Size 15.30 x 17.80mm (6 3/4 x 8 Ligne)
Movement Height 3.15mm
Hands: Hour & Minute
Battery 377
Hand Sizes: Min .70, Hr 1.20
£1.80
or
Movement, Miyota 2035
2035M
Add to Favourites
Size 15.30 x 17.80mm (6¾ x 8 Ligne)
Height 3.15mm
Hour, Minute & Center Seconds
Battery 377
3 Year Battery Life
Hand Ø: Min .70, Hr 1.20, Sec .17
Hi   I should remove the AG1 battery and fit a renata watch batters  the cheap ones have a tendency to leak, and if they do the watch is usually ruined.
Cousins have 2035@ £1.25.    5Y20 @ £5.15.   2030 is Obsolete . all 6 3/4  X   8. depends on whether it is a three hand or two hand movement. Attached is the tech manual to help you.     cheers
2030.pdf
Thank you everyone for your help. If I manage to work on a thousand watches in my lifetime, this will be my most important one
I have gotten many of these to run again with the use of some quick dry electronic spray. use a blower to push air around and get the spray to dry up.  than follow with a dab of Teflon\silicon electronic lube to those tiny pivot holes.  You may even slip some lube direct to any gears. about a 50% chance it may start up.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
    • Hi there Stoller,   Caliber is generally stamped under the balance or thereabouts.  Caliber can't neccessarily be identified by bridge layout. Regs
