Here is the dial.  Since posting, I discovered that the alarm function works fine.  However, I have not figured out how to set the alarm.  Possibly a broken component??  The movement is running briskly, so I am very optimistic.
2 minutes ago, LittleWatchShop said:
Excellent!  Appears that there is something malfunctioning in the alarm-set feature.  Will investigate and report back!
That would be great
Hmmm, removed the two case screws and brackets, movement is loose (rotates a few degrees in case) but does not come out.  Need to ponder this and be very careful.  I don't think it is a front loader.
I have reassembled this watch.  It is running great so far.  Alarm works fine.  I have sent an email to "International Dial" to see if they have the die for this dial (or the Vulcain equivalent).  If they do, I will probably spend the money to have it refinished.  The case is in very good shape: 10K GF.
Stay tuned.
Stay tuned.
International Dial has the die for this watch.  They will refinish dial and hands for about $100.  I have ordered some crystals (sized above and below what I measured) and once I fit a crystal, I will send the dial for refinishing.  Should be exciting.
Just now, PastorChris said:
Looks like a fun project, interesting watch, and it all seems to be coming together.
According the USPS tracking number the dial arrives at International Dial tomorrow.  Give-em a week and then it is back to me.  I will post the result.
